StarTech.com Fiber Media Converter Gigabit 1000Mbps MM Fibre LC 550m
Quicklinx: 85DGWS00 Mfr#: ET91000LC2
£154.65 ex VAT
£185.58 inc VAT
Convert and extend a Gigabit Ethernet connection up to 550 m / 1804 ft over Multimode LC fiber. The ET91000LC2 1000 Mbps Gigabit Multimode Fiber Media Converter (LC, 550m) lets you extend a Gigabit Ethernet network over multimode fiber, at distances up to 550m (1804 ft).
A cost-effective solution for connecting a Gigabit Ethernet (1000Base-T) network to remote network segments over a (1000Base-LX/SX) fiber backbone, this GbE to MM fiber converter supports full Gigabit speeds for ideal network performance and scalability. Designed to offer a durable and convenient Ethernet-to-fiber solution, the Ethernet to LC Fiber converter features an all-steel chassis, and a simple plug-and-play installation with minimal configuration required.
For added versatility, this fiber media converter supports standalone operation, or installation into the 20 Slot, 2U Rackmount Chassis (ETCHS2U), as well as a replaceable SFP slot.
  • Efficient data transfer
    Experience Gigabit Ethernet performance with a data transfer rate of 1 Gbps, ensuring swift and efficient data transmission for your network.
  • Flexible connectivity
    Equipped with both RJ-45 and LC multi-mode connectors, this media converter adapts easily to various networking configurations, enhancing versatility.
  • Durable design
    Designed to withstand environmental challenges, this device operates within a temperature range of 0°C to 60°C, making it suitable for a variety of settings.
  • User-friendly setup
    Plug-and-play compatibility allows for a straightforward installation process, enabling users to quickly integrate the device into their existing network.
  • Long-range capability
    Extend network connections efficiently with a maximum transfer distance of 550 m, facilitating robust networking over larger areas.
StarTech.com Multimode (MM) LC Fiber Media Converter for 1Gbe Network - 550m Range - Gigabit Ethernet - 850nm - with SFP Transceiver (ET91000LC2) - fibre media converter - 1GbE
Fibre media converter - RJ-45 / LC multi-mode
External
North America, United Kingdom, Europe
Cabling Type
1000Base-LX, 1000Base-SX, 1000Base-T
Data Transfer Rate
1 Gbps
Optical Wave Length
850 nm
1GbE
Max Transfer Distance
550 m
AC 120/230 V
9.5 cm x 16 cm x 2 cm
0.62 kg
P/N: ETCHS2U, SVA12M2NEUA, SVA12M5NA
External
Wired
Cabling Type
1GbE
Data Transfer Rate
1 Gbps
Optical Wave Length
850 nm
550 m
Auto-uplink (auto MDI/MDI-X), half duplex mode, full duplex mode, rugged
1 x Ethernet 1000Base-T - RJ-45 female , 1 x Ethernet 1000Base-LX/1000Base-SX - LC multi-mode female x 2
MTBF
65,000 hours
Plug and Play, FCC, RoHS
External power adapter
AC 120/230 V
9.5 cm
16 cm
2 cm
0.62 kg
60 °C
10 - 90%
85DG StarTech.com Fiber Media Converter Gigabit 1000Mbps MM Fibre LC 550m In Stock £154.65
85DG StarTech.com Fiber Media Converter - Open In Stock £43.33
85DG StarTech.com Fiber Media Converter - w/ SFP In Stock £67.70
85DG StarTech.com GbE Fiber Media Converter 10km In Stock £183.62
85DG StarTech.com DC Power Adapter - 12V, 5A In Stock £44.06
Type: Media Converter
