StarTech.com Fiber Media Converter, TAA
Quicklinx: JG6KWS00 Mfr#: MCM10G6SSFP
Hurry, only 3 left in stock!
£292.64 ex VAT
£351.16 inc VAT
Connect a high-speed copper (10GBASE-T) network to a fiber (10GBASE-R) network using a 10GbE SFP+ transceiver.
Flexible, High-Speed Copper-to-Fiber Conversion
This compact 10G media converter enables seamless copper-to-fiber conversion for network upgrades or long-distance extension. Featuring an open SFP+ slot, it converts 100M to - 10GBASE-T RJ-45 to 10G fiber and supports both multi-mode and single-mode transceivers (10GBASE-SR/LR) for flexible deployment across enterprise and telecom environments.
Versatile Mounting and Deployment
Ideal for structured wiring closets, server rooms, or remote network upgrades, the converter supports wall-mount, DIN rail, and chassis installations. It can operate as a standalone device or integrate into a media converter chassis system.
Optimized for Mixed-Speed Networks
Built for maximum compatibility, the converter supports IEEE 802.3 standards, 16K Jumbo Frames, auto MDI/MDI-X, and full-duplex flow control. With plug-and-play setup and reliable diagnostics, it ensures consistent performance across legacy and high-speed links.
Efficient, Compact Design
With low 3.75W (typical) power consumption via 5V DC input, this power-efficient converter operates in environments ranging from 0°C to 50°C. It avoids PoE-related conflicts and is ideal for compact, power-sensitive deployments.
Startech - fibre media converter - 100Mb LAN, 1GbE, 10GbE, 5GbE, 2.5GbE - TAA Compliant
Fibre media converter - SFP+ / RJ-45
Wall / rack / DIN rail mountable
Cabling Type
10GBase-LR, 10GBase-SR, 10GBase-X, 10GBase-T, 10GBase-R
Data Transfer Rate
10 Gbps
Transmission Medium
Fibre optic
AC 100-240 V
7 cm x 9.4 cm x 2.6 cm
TAA Compliant
Wired
Cabling Type
Data Transfer Rate
10 Gbps
Status Indicators
Power, link/speed
Auto-negotiation, auto-uplink (auto MDI/MDI-X), full duplex mode, metal housing, 16 KB Jumbo Frame, single-mode, LED status indicators, multimode, compact
IEEE 802.3
1 x Ethernet 10GBase-X - SFP+ female , 1 x Ethernet 10GBase-T - RJ-45 female
Power adapter
MTBF
50,000 hours
Plug and Play, FCC, RoHS, WEEE
TAA Compliant
External power adapter
AC 100-240 V
3.75 watt
7 cm
9.4 cm
2.6 cm
Shipping Width
7 cm
Shipping Depth
9.4 cm
Shipping Height
2.6 cm
Shipping Weight
500 g
50 °C
5 - 95% RH (non-condensing)
