The fiber media converter provides a cost-effective way to transparently convert copper to fiber, or fiber to copper, for connecting remote sub networks to larger fiber optic networks.
Extend your GbE network cost effectively
The fiber media converter provides a cost-effective way to transparently convert copper to fiber, or fiber to copper, for connecting remote sub networks to larger fiber optic networks. -
Reliable and scalable network connectivity
The media converter delivers a simple and reliable solution for connecting Gigabit Ethernet networks to remote locations, while ensuring solid network performance. It provides optimal network scalability for connecting two or more Ethernet network nodes.
- StarTech.com Singlemode (SM) SC Fiber Media Converter for 10/100/1000 Network, 10km, Gigabit Ethernet, 1310nm, w/ Auto Negotiation, Gigabit Ethernet to Single Mode (SMF) SC Fiber Converter - Ethernet Over Fiber (MCMGBSCSM10) - fibre media converter - 10Mb LAN, 100Mb LAN, 1GbE
- Fibre media converter - RJ-45 / SC single-mode
- Form Factor
- External
- Cabling Type
- 1000Base-LX, 100Base-TX, 1000Base-T
- Data Transfer Rate
- 1 Gbps
- Optical Wave Length
- 1310 nm
- Data Link Protocol
- Transmission Medium
- Fibre optic
- Max Transfer Distance
- 10 km
- Power
- AC 100 - 240 V
- 7 cm x 9.7 cm x 2.6 cm
- 200 g
- 2-year warranty
- Form Factor
- External
- Connectivity Technology
- Wired
- Cabling Type
- 1 Gbps
- 1310 nm
- 10 km
- Status Indicators
- Port duplex mode, power, link/activity
- Auto-uplink (auto MDI/MDI-X), full duplex mode, surge protection, 9 KB Jumbo Frame
- IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3x
- 1 x Ethernet 100Base-TX/1000Base-T - RJ-45 female , 1 x Ethernet 1000Base-LX - SC single-mode female x 2
- MTBF
- 50,000 hours
- cUL, FCC, RoHS, WEEE
- Power Device
- External power adapter
- Voltage Required
- AC 100 - 240 V
- 5 Watt
- 7 cm
- 9.7 cm
- 2.6 cm
- 200 g
- Limited warranty - 2 years
- 0 °C
- 50 °C
- 5 - 90%
