Fan out eight fibers from a 40Gbps MPO connection to four 10Gbps LC connections. This MPO/MTP to 8x LC breakout cable lets you fan out a single 40Gbps connection from a 40GBase-SR4 QSFP+ transceiver to four 10Gbps LC SFP+ transceivers.
The push-and-pull tabs optimize accessibility and let you install or remove the connectors with one hand, without using additional tools. Plus, the slim uniboot design of the LC connectors saves space and improves cable management.
The MPO cable is housed in a plenum-rated jacket and is ideal for installations where CMP fire rating is required.
Each OM3 fiber cable has been individually tested for insertion loss and return loss. The full test report is included in each cable bag.
Efficient design
This breakout cable features MTP/MPO on one end and LC connectors on the other, facilitating easy connection to network devices while maintaining high data integrity. -
Flexible connectivity
Equipped with 8 female LC connectors, the cable enables easy connection to multiple endpoints, perfect for expanding network capabilities. -
High-speed performance
With compliance to OM3 standards, this fiber optic cable delivers fast data rates up to 40 Gb, ensuring smooth operation in demanding network environments. -
Safe installation
The plenum-rated design allows for installation in air circulation spaces, adhering to safety standards while offering reliable performance. -
Durable construction
Constructed with 50 / 125 micron core and cladding dimensions, the cable provides robustness for long-lasting and effective signal transmission.
- StarTech.com MTP to LC Breakout Cable - 3 ft / 1m - OM3 Multimode - 40Gb - Pull Tab - Plenum - MPO / MTP Connector - Fiber Optic Cable (MPO8LCPL1M) - breakout cable - 1 m - aqua
- Breakout cable - OM3
- Technology
- Fibre optic
- Type of Fibre Optics
- Multimode
- Plenum
- Length
- 1 m
- Core / Cladding Diameter
- 50 / 125 micron
- Connector
- MTP/MPO multi-mode - female - push/pull
- Connector (Second End)
- 8 x LC multi-mode - male - push/pull
- Aqua
- Limited lifetime warranty
- Network Cable Type
- Technology
- Fibre optic
- Multimode
- 50 / 125 micron
- Plenum
- Length
- 1 m
- 8.6 g
- Aqua
- Connector
- RoHS
StarTech.com Fiber Breakout Cable 1m MPO / MTP to LC | In Stock | £50.89 |
