StarTech.com Extreme Networks 10338 Comp SFP Copper Module - 10GBase-T
Quicklinx: FJ6KWS00 Mfr#: 10338-ST
£152.26 ex VAT
£182.71 inc VAT
The 10338-ST is an Extreme Networks 10338 compatible copper transceiver module that has been designed, programmed and tested to work with Extreme Networks brand switches and routers. It delivers dependable 10 GbE connectivity over copper cable, for 10GBase-T compliant networks, with a maximum distance of up to 30 m (98.4 ft).
This copper module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
StarTech.com Extreme Networks 10338 Compatible SFP+ Module, 1000BASE-T, SFP+ to RJ45 Cat6 and Cat5e, 10GE Gigabit Ethernet SFP+, RJ-45 (Copper) 30m, Mini GBIC Transceiver SFP Plus Module - Lifetime Warranty (10338-ST) - SFP (mini-GBIC) transceiver module - 1GbE
SFP (mini-GBIC) transceiver module - RJ-45
Plug-in module
Cabling Type
10Base-T, 100Base-TX, 1000Base-T
Data Transfer Rate
1 Gbps
1GbE
Max Transfer Distance
30 m
6.8 cm x 1.37 cm x 1.38 cm
15 g
Plug-in module
Wired
Cabling Type
1GbE
Data Transfer Rate
1 Gbps
30 m
Full duplex mode
IEEE 802.3
1 x Ethernet 1000Base-T - RJ-45 female
MTBF
510,469,759 hours
FCC, RoHS, REACH, MSA
1 Watt
6.8 cm
1.37 cm
1.38 cm
15 g
Shipping Width
9 cm
Shipping Depth
11.5 cm
Shipping Height
3.1 cm
Shipping Weight
50 g
Limited warranty - lifetime
