The 10338-ST is an Extreme Networks 10338 compatible copper transceiver module that has been designed, programmed and tested to work with Extreme Networks brand switches and routers. It delivers dependable 10 GbE connectivity over copper cable, for 10GBase-T compliant networks, with a maximum distance of up to 30 m (98.4 ft).
This copper module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
 - StarTech.com Extreme Networks 10338 Compatible SFP+ Module, 1000BASE-T, SFP+ to RJ45 Cat6 and Cat5e, 10GE Gigabit Ethernet SFP+, RJ-45 (Copper) 30m, Mini GBIC Transceiver SFP Plus Module - Lifetime Warranty (10338-ST) - SFP (mini-GBIC) transceiver module - 1GbE
 - SFP (mini-GBIC) transceiver module - RJ-45
- Form Factor
 - Plug-in module
- Cabling Type
 - 10Base-T, 100Base-TX, 1000Base-T
- Data Transfer Rate
 - 1 Gbps
- Data Link Protocol
 - 1GbE
- Max Transfer Distance
 - 30 m
- OEM Manufacturer Equivalent Part Number
 - Extreme Networks 10338
 - 6.8 cm x 1.37 cm x 1.38 cm
 - 15 g
 - Limited lifetime warranty
- Form Factor
 - Plug-in module
- Connectivity Technology
 - Wired
- Cabling Type
 - 1GbE
 - 1 Gbps
 - 30 m
 - Full duplex mode
 - IEEE 802.3
 - 1 x Ethernet 1000Base-T - RJ-45 female
- MTBF
 - 510,469,759 hours
 - FCC, RoHS, REACH, MSA
 - 1 Watt
 - 6.8 cm
 - 1.37 cm
 - 1.38 cm
 - 15 g
- Shipping Width
 - 9 cm
- Shipping Depth
 - 11.5 cm
- Shipping Height
 - 3.1 cm
- Shipping Weight
 - 50 g
 - Limited warranty - lifetime
