StarTech.com Extreme Networks 10301 Comp SFP+ MM Module - 10GBase-SR
Quicklinx: FJ6GWS00 Mfr#: 10301-ST
£123.93 ex VAT
£148.71 inc VAT
The 10301-ST is an Extreme Networks 10301 compatible fiber transceiver module that has been designed, programmed and tested to work with Extreme Networks brand switches and routers. It delivers dependable 10 GbE connectivity over fiber cable, for 10GBase-SR compliant networks, with a maximum distance of up to 300 m (984 ft).
This SFP+ fiber module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
StarTech.com Extreme Networks 10301 Compatible SFP+ Module, 10GBASE-SR, 10GbE Multimode Fiber MMF Optic Transceiver, 10GE Gigabit Ethernet SFP+, LC 300m, 850nm, DDM, Mini GBIC SFP+ Module - Lifetime Warranty (10301-ST) - SFP+ transceiver module - 10GbE
SFP+ transceiver module - LC multi-mode
Plug-in module
Cabling Type
10GBase-SR
Data Transfer Rate
10 Gbps
Optical Wave Length
850 nm
10GbE
Max Transfer Distance
300 m
5.84 cm x 1.39 cm x 1.26 cm
20 g
Plug-in module
Wired
Cabling Type
10GBase-SR
10GbE
Data Transfer Rate
10 Gbps
Optical Wave Length
850 nm
300 m
Full duplex mode, Digital Diagnostics Monitoring (DDM)
1 x Ethernet 10GBase-SR - LC multi-mode female x 2
MTBF
498,745,585 hours
FCC, MSA
1.3 Watt
5.84 cm
1.39 cm
1.26 cm
20 g
Shipping Width
9 cm
Shipping Depth
11.5 cm
Shipping Height
3.1 cm
Shipping Weight
50 g
Limited warranty - lifetime
