StarTech.com Extreme Networks 10057 SFP Module - Lifetime Warranty - 1000
Quicklinx: FHGYWS00 Mfr#: 10057-ST
£29.18 ex VAT
£35.01 inc VAT
The 10057-ST is an Extreme Networks 10057 compatible upstream fiber SFP transceiver which pairs with StarTech.com's 10056-ST. They are designed, programmed and tested to work with 1000Base-BX-U compatible Extreme Networks switches and routers. The SFP transceiver module supports a maximum distance of up to 10 km (6.2 mi) and delivers dependable 1 GbE connectivity over fiber cabling.
This SFP fiber module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP Cables, providing the convenience and reliability you need to ensure dependable network performance.
StarTech.com Extreme Networks 10057 Compatible SFP Module, 1000BASE-BX-U, 1 Gigabit Ethernet Bi-Directional (BiDi) Fiber Single Strand SFP (SMF), LC 10km, Mini GBIC Transceiver SFP Module - Lifetime Warranty (10057-ST) - SFP (mini-GBIC) transceiver module - 1GbE
SFP (mini-GBIC) transceiver module - LC single-mode
Plug-in module
Cabling Type
1000Base-BX-U
Data Transfer Rate
1 Gbps
Optical Wave Length
1310 (RX) / 1490 (TX) nm
1GbE
Max Transfer Distance
10 km
5.66 cm x 1.37 cm x 1.25 cm
20 g
Extreme Networks Summit X450a-24t, X450a-24tDC, X450a-48t, X450e-24p
Plug-in module
Wired
Cabling Type
1000Base-BX-U
1GbE
Data Transfer Rate
1 Gbps
Optical Wave Length
10 km
Full duplex mode, Digital Diagnostics Monitoring (DDM)
1 x Ethernet 1000Base-BX-U - LC single-mode female
MTBF
286,217,327 hours
FCC, RoHS, REACH, MSA
1.3 Watt
5.66 cm
1.37 cm
1.25 cm
20 g
Shipping Width
9 cm
Shipping Depth
11.5 cm
Shipping Height
3.1 cm
Shipping Weight
50 g
Limited warranty - lifetime
