StarTech.com Extreme Networks 10052 Comp SFP SM Module - 1000Base-LX
Quicklinx: FHGXWS00 Mfr#: 10052-ST
Type: Modules
£23.91 ex VAT
£28.69 inc VAT
The 10052-ST is an Extreme Networks 10052 compatible fiber transceiver module that has been designed, programmed and tested to work with Extreme Networks brand switches and routers. It delivers dependable 1 GbE connectivity over fiber cable, for 1000Base-LX compliant networks, with a maximum distance of up to 10 km (6.2 mi).
This SFP fiber module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
StarTech.com Extreme Networks 10052 Compatible SFP Module, 1000BASE-LX, 1GbE Single Mode Fiber SMF Optic Transceiver, 1 Gigabit Ethernet SFP, LC 10km, 1310nm, DDM, Mini GBIC - Lifetime Warranty (10052-ST) - SFP (mini-GBIC) transceiver module - 1GbE
SFP (mini-GBIC) transceiver module - LC single-mode
Plug-in module
Cabling Type
1000Base-LX
Data Transfer Rate
1 Gbps
Optical Wave Length
1310 nm
1GbE
Max Transfer Distance
10 km
5.56 cm x 1.37 cm x 1.25 cm
18 g
Summit 200-24, 200-48, 24e3, 400-48t; Alpine 3802, 3804, 3808; Extreme Networks GM-16T3, GM-16X3; BlackDiamond 10808, 6800; Summit 400-48t
Plug-in module
Wired
Cabling Type
1000Base-LX
1GbE
Data Transfer Rate
1 Gbps
Optical Wave Length
1310 nm
10 km
Full duplex capability, Digital Diagnostics Monitoring (DDM)
1 x Ethernet 1000Base-LX - LC single-mode female x 2
MTBF
634,210,013 hours
FCC, MSA
1.3 Watt
5.56 cm
1.37 cm
1.25 cm
18 g
Shipping Width
9 cm
Shipping Depth
11.5 cm
Shipping Height
3.1 cm
Shipping Weight
50 g
Limited warranty - lifetime
Summit 200-24, 200-48, 24e3, 400-48t , Alpine 3802, 3804, 3808 , Extreme Networks GM-16T3, GM-16X3 , Extreme Networks BlackDiamond 10808, 6800 , Extreme Networks Summit 400-48t
Type: Modules
