StarTech.com Extreme Networks 10050 Comp SFP Copper Module - 1000Base-T
Quicklinx: FHGRWS00 Mfr#: 10050-ST
£33.45 ex VAT
£40.14 inc VAT
The 10050-ST is an Extreme Networks 10050 compatible copper transceiver module that has been designed, programmed and tested to work with Extreme Networks brand switches and routers. It delivers dependable 1 GbE connectivity over copper cable, for 1000Base-T compliant networks, with a maximum distance of up to 100 m (328 ft).
This SFP copper module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
StarTech.com Extreme Networks 10050 Compatible SFP Module - 1000BASE-T - SFP to RJ45 Cat6/Cat5e - 1GE Gigabit Ethernet SFP - RJ-45 100m Mini GBIC Transceiver - Lifetime Warranty (10050-ST) - SFP (mini-GBIC) transceiver module - 1GbE
SFP (mini-GBIC) transceiver module - RJ-45
Plug-in module
Cabling Type
10Base-T, 100Base-TX, 1000Base-T
Data Transfer Rate
1 Gbps
1GbE
Max Transfer Distance
100 m
6.8 cm x 1.37 cm x 1.38 cm
15 g
Plug-in module
Wired
Cabling Type
1GbE
Data Transfer Rate
1 Gbps
100 m
Full duplex capability
IEEE 802.3
1 x Ethernet 1000Base-T - RJ-45 female
MTBF
510,469,759 hours
FCC, MSA
6.8 cm
1.37 cm
1.38 cm
15 g
Shipping Width
9 cm
Shipping Depth
11.5 cm
Shipping Height
3.1 cm
Shipping Weight
50 g
Limited warranty - lifetime
