Brand
StarTech.com ExpressCard 34mm to 54mm Stabilizer Adapter - 3 Pack
Quicklinx: 837DWS00 Mfr#: ECBRACKET2
Compatibility: PC
14 in stock
£2.19 ex VAT
£2.62 inc VAT
Install a 34mm ExpressCard into a 54mm ExpressCard slot, without card slippage. The ECBRACKET2 ExpressCard 34mm to 54mm Stabilizer Adapter helps prevent side-to-side movement of a 34mm ExpressCard, while the card is connected to a 54mm ExpressCard slot.
The ExpressCard 34/54 stabilizer can be attached to almost any 34mm ExpressCard to provide added stability and security for your card adapter, including flushmount designed cards.
The ExpressCard 34 stabilizer bracket comes in a package of three, so you won't need to swap adapters when using different EC cards.
StarTech.com ExpressCard 34mm to 54mm Stabilizer Adapter - 3 Pack - ExpressCard bRacket - ExpressCard stabilizer 34 to 54 (ECBRACKET2) - ExpressCard slot stabilizer adapter
Packaged Quantity
3 (specifications are for single item)
0.3 cm x 4 cm x 2.1 cm
2.2 g
Packaged Quantity
0.3 cm
4 cm
2.1 cm
2.2 g
RoHS
Limited warranty: - 2 years
Compatibility: PC
Stock Status: In stock
