The 1-Port Gigabit Network Isolator from StarTech.com efficiently separates devices in high-speed networks. Equipped with a plastic housing, it ensures durability while accommodating network cables with up to 1000 Mbps speeds. This versatile network coupler supports both RJ-45 left and right connector types, making it ideal for connecting various devices seamlessly. Its compliance with standards like IEEE 802.3ab enhances reliability, while the Plug-and-Play design ensures hassle-free installation in both CAT 5 and CAT 6 networks. Designed to withstand a range of environmental conditions, this network isolator operates effectively at temperatures between -10°C and 70°C. It meets several regulatory standards, including FCC, RoHS, and WEEE, ensuring responsible use in different settings. Enhance network performance and stability with this efficient isolator that ensures dependable connections and robust performance in your networking solutions.
Reliable connection
The 1-Port Gigabit Network Isolator supports rapid data speeds of up to 1000 Mbps, ensuring robust performance for all connected devices. -
Durable construction
Featuring a sturdy plastic housing, this isolator is built to withstand daily use while maintaining a reliable connection. -
Wide compatibility
With RJ-45 left and right connector types, this product works with a variety of network devices. -
Easy installation
The Plug-and-Play design allows for seamless integration into existing setups, enhancing network reliability. -
Environmentally compliant
This product adheres to multiple compliance standards including FCC, RoHS, and WEEE, ensuring it is a responsible choice for networking needs.
- StarTech.com 1-Port Gigabit Network Isolator, RJ45 Ethernet Coupler, 4kV - network coupler - TAA Compliant - black
- Network coupler - CAT 5/6 - IEEE 802.3ab/IEEE 802.3
- Up to 1000 Mbps, plastic housing
- Connector
- RJ-45 - female
- Connector (Second End)
- RJ-45 - female
- Black
- TAA Compliant
- 2-year warranty
- Network Cable Type
- 6.7 cm
- 3.3 cm
- 2.4 cm
- 31 g
- Black
- Connector
- RJ-45 - female
- RJ-45 - female
- RoHS, WEEE, FCC, IEC 62368-1, EN 55032, EN 55035, Plug and Play, IP40
- TAA Compliant
- 2-year warranty
- -10 °C
- 70 °C
