StarTech.com Ergonomic Rocking Foot Rest with Integrated Cable Management
Quicklinx: FP9JWS00 Mfr#: FTRST2
Hurry, only 3 left in stock!
£18.13 ex VAT
£21.75 inc VAT
Under-Desk Footrest Clamshell Design Supports Single Row Power Bars. This under-desk foot rest helps to increase your comfort and productivity by keeping you ergonomically positioned throughout the day. It's a cost-effective way to modify your workstation. Ensure maximum comfort at your desk the rocking feature of the foot rest.
Integrated Power Bar Storage
The ergonomic foot rest features integrated storage for single row power bar, as well as integrated cable management for any devices connected to the power bar. This feature provides comfort without compromising the cable management of your workstation.
Increase Movement While Sitting
The rocking design lets you exercise your feet back and forth, helping to stretch your ankles and calves. The ergonomic foot stool for your desk elevates your feet to improve your blood circulation and reduce fatigue.
Non-slip Rubberized Surface
The rubberized platform surface prevents your feet from slipping off the foot stand making it ideal for use at your desk.
The Choice of IT Pros Since 1985
StarTech.com conducts thorough compatibility and performance testing on all our products to ensure we are meeting or exceeding industry standards and providing high-quality products to IT Professionals. Our local StarTech.com Technical Advisors have broad product expertise and work directly with our StarTech.com Engineers to provide support for our customers both pre and post-sales.
The FTRST2 is backed by a StarTech.com 5-year warranty and free lifetime technical support.
StarTech.com Ergonomic Foot Rest, Rocking Footrest w/ Cable Management/Storage, Under Desk Foot Support Stand, Comfortable Black Foot Rest for Office/Computer Workstation, Non Slip Rocker - Under Desk Foot Rest (FTRST2) - footrest
Footrest
Material
Rubber
5 years
Footrest
Material
Rubber
Non-skid surface, rocking motion, cable management
Warranty
5 years
40 cm
30 cm
