Create an ergonomic setup with this sturdy monitor riser stand. Lift a display closer to eye level for comfortable viewing while improving desk space and organization.
Optimize desk space
Fixed-height riser (3.5"/90.5 mm) accommodates desktop monitors or laptops up to 33 lbs. (15 kg). Free up desk space and conveniently store keyboard, mouse, or accessories underneath when unused. -
Slip protection and stability
Non-skid pads at the bottom provide stability and protect the desk surface. -
Simple assembly
Quickly assemble and deploy with only three main components. The platform is constructed of durable steel for strength and durability.
- StarTech.com Ergonomic Monitor Riser Stand, 33lb Max, Fixed height 3.5in - monitor stand - TAA Compliant
- Product Type
- Monitor stand
- Placing / Mounting
- Desktop
- Package Content
- 2 riser supports, 4 screws, 4 rubber feet
- White & silver
- Product Material
- Steel, plastic
- 54.46 cm x 22 cm x 9.05 cm
- 2 kg
- TAA Compliant
- 5-year warranty
- Product Type
- Monitor stand
- Desktop
- Package Content
- Max Load Weight
- 15 kg
- Product Material
- Steel, plastic
- 54.46 cm - 22 cm - 9.05 cm
- 2 kg
- Shipping Dimensions (WxDxH) / Weight
- 64.7 cm x 28.4 cm x 5.9 cm / 2.6 kg
- White & silver
- Non-skid pads
- TAA Compliant
- Limited warranty - 5 years
StarTech.com 15in Laptop Privacy Screen - Matte or Glossy - 16:9 Ratio | In Stock | £32.40 |
StarTech.com 13in Laptop Privacy Screen - 16:10 Aspect Ratio | In Stock | £33.45 |
StarTech.com 15in Laptop Privacy Screen - Magnetic - 16:10 Aspect Ratio | In Stock | £46.69 |
StarTech.com 13.3in Laptop Privacy Screen | In Stock | £9.02 |
StarTech.com 16in MacBook Privacy Screen | In Stock | £34.00 |
