StarTech.com Ergonomic Monitor Riser Stand
Quicklinx: HQ2QWS00 Mfr#: 1MFSW-MONITOR-RISER
£32.89 ex VAT
£39.46 inc VAT
Create an ergonomic setup with this sturdy monitor riser stand. Lift a display closer to eye level for comfortable viewing while improving desk space and organization.
  • Optimize desk space
    Fixed-height riser (3.5"/90.5 mm) accommodates desktop monitors or laptops up to 33 lbs. (15 kg). Free up desk space and conveniently store keyboard, mouse, or accessories underneath when unused.
  • Slip protection and stability
    Non-skid pads at the bottom provide stability and protect the desk surface.
  • Simple assembly
    Quickly assemble and deploy with only three main components. The platform is constructed of durable steel for strength and durability.
StarTech.com Ergonomic Monitor Riser Stand, 33lb Max, Fixed height 3.5in - monitor stand - TAA Compliant
Monitor stand
Placing / Mounting
Desktop
Package Content
2 riser supports, 4 screws, 4 rubber feet
White & silver
Product Material
Steel, plastic
54.46 cm x 22 cm x 9.05 cm
2 kg
TAA Compliant
5-year warranty
Monitor stand
Placing / Mounting
Desktop
Package Content
Max Load Weight
15 kg
Product Material
Steel, plastic
54.46 cm - 22 cm - 9.05 cm
2 kg
64.7 cm x 28.4 cm x 5.9 cm / 2.6 kg
White & silver
Non-skid pads
TAA Compliant
Limited warranty - 5 years
HQ2Q StarTech.com 15in Laptop Privacy Screen - Matte or Glossy - 16:9 Ratio In Stock £31.60
HQ2Q StarTech.com 13in Laptop Privacy Screen - 16:10 Aspect Ratio In Stock £32.64
HQ2Q StarTech.com 13.3in Laptop Privacy Screen In Stock £9.02
HQ2Q StarTech.com 16in MacBook Privacy Screen In Stock £32.66
