Convert and scale a DVI-D signal to work with a VGA monitor. The DVI2VGA DVI to VGA converter with scaler allows you to convert a DVI Digital (DVI-D) signal to a VGA signal, saving you time and money by eliminating the need to purchase costly new hardware to make your devices compatible.
The scaler/converter features an easy to use On-Screen Display (OSD) that allows you to take full control of your display and the resolutions you need, in PC or HDTV mode. The OSD also features adjustments for brightness, color, contrast and horizontal/vertical positioning.
The DVI VGA scaler/converter includes a plastic bracket for wall mounting, or side panel installation.
- StarTech.com DVI to VGA Video Converter with Scaler - video converter - black
- Video converter
- Max Resolution
- 1280 x 1024
- 1 x DVI-D input - 24+1 pin digital DVI , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x DVI-D input - 24+1 pin digital DVI (on supplied cable)
- 7.7 cm x 14.6 cm x 3 cm
- Enclosure Colour
- Black
- 2-year warranty
- Video converter
- Max Resolution
- 1280 x 1024
- 1 x DVI-D input - 24+1 pin digital DVI - female , 1 x VGA output - 15 pin HD D-Sub (HD-15) - female , 1 x DVI-D input - 24+1 pin digital DVI (on supplied cable) - male
- Cables Included
- 1 x DVI cable - 1.83 m
- 7.7 cm
- 14.6 cm
- 3 cm
- Enclosure Colour
- Black
- Limited warranty - 2 years
