StarTech.com DVI to VGA Cable Adapter M/F - Black - 10 Pack
Quicklinx: 9ZJFWS00 Mfr#: DVIVGAMFB10P
Type: DVI Splitter
Length: [N/A]
Hurry, only 3 left in stock!
£26.82 ex VAT
£32.18 inc VAT
Connect your VGA Displays to DVI-I video sources. The DVIVGAMFB10P 10-pack of Black DVI-I to VGA Adapters offers a cost-effective option when you have multiple DVI-enabled computers to connect to VGA monitors.
At a lower cost per unit, these DVI to VGA adapters convert DVI male connectors to VGA female connectors - a perfect solution for schools, and other organizations to connect DVI-I desktop or laptop computers to VGA monitors or projectors.
The adapters are constructed of high-quality materials to ensure dependability.
This product is intended for connections between DVI-I and VGA devices. If your devices use a DVI-D connector, please refer to StarTech.com's DVI to VGA Converter (DVI2VGACON).
StarTech.com DVI to VGA Cable Adapter - DVI (M) to VGA (F) - 10 Pack - Black - DVI Male to VGA Female (DVIVGAMFB10P) - VGA adapter
VGA adapter
Packaged Quantity
10 (specifications are for single item)
Molded, thumbscrews
Connector
HD-15 (VGA) - female
Connector (Second End)
DVI-I - male
Packaged Quantity
VGA adapter
Plated Connector
Nickel
Molded, thumbscrews
Connector
15 pin HD D-Sub (HD-15) - female
24+5 pin combined DVI - male
9ZJF StarTech.com DVI to VGA Cable Adapter - M/F In Stock £5.25
9ZJF StarTech.com DVI to VGA Cable Adapter - Black - M/F In Stock £6.21
9ZJF StarTech.com DVI to VGA Cable Adapter M/F - Black - 10 Pack In Stock £26.82
Type: DVI Splitter
Length: [N/A]
