The DVIVGAMF DVI-I to VGA Display Adapter (M/F) is used to convert a DVI Male connector to a VGA female connector. The DVI to VGA adapter is constructed of high quality materials to ensure dependability.
This product is intended for connections between DVI-I and VGA devices. If your device uses a DVI-D connector, please refer to StarTech.com's DVI to VGA Converter DVI2VGACON.
Versatile compatibility
This adapter connects devices with male DVI outputs to those with female VGA inputs, making it suitable for a variety of applications. -
Reliable signal transmission
Designed to maintain a strong connection, the adapter minimizes signal loss, ensuring clear and consistent picture quality.
- StarTech.com DVI to VGA Cable Adapter - DVI (M) to VGA (F) - 1 Pack - Male DVI to Female VGA (DVIVGAMF) - VGA adapter
- VGA adapter
- Connector
- DVI-I - male
- Connector (Second End)
- HD-15 (VGA) - female
- Beige
- Limited lifetime warranty
- Designed For
- P/N: MXT101MMHD15, MXT101MMHD6
- VGA adapter
- Beige
- Connector
- 24+5 pin combined DVI - male
- 15 pin HD D-Sub (HD-15) - female
- Designed For
StarTech.com DVI to VGA Cable Adapter - M/F | In Stock | £5.17 |
StarTech.com DVI to VGA Cable Adapter - Black - M/F | In Stock | £3.87 |
StarTech.com DVI to VGA Cable Adapter - Black - F/M | In Stock | £7.33 |
StarTech.com 8in DVI to VGA Cable Adapter - DVI-I Male to VGA Female | In Stock | £7.63 |
StarTech.com DVI-D to VGA Active Adapter Converter Cable – 1920x1200 | In Stock | £24.04 |
Customer reviews
Write a review for the StarTech.com DVI to VGA Cable Adapter - M/F here!
Good Stuff
Reviewed by M@ Morgan. Review Posted 20/01/2007
does what it say it should!! why not buy 2!?
Overall
Ease of use
Value for money
Does what it says!
Reviewed by Matt. Review Posted 14/02/2007
Very good adapter! High quality and does exactly what it says!
Overall
Ease of use
Value for money
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
