Product
StarTech.com DVI to HDMI Video Adapter
Quicklinx: C7CCWS00 Mfr#: DVI2HD
23 in stock
£29.19 ex VAT
£35.02 inc VAT
Standard delivery Delivered within 3-5 working days
Connect an HDMI display or projector to your DVI-D computer, with audio and power provided over USB. This DVI to HDMI adapter lets you connect your DVI laptop or desktop computer to an HDMI display or projector. The adapter works with any DVI output, but when you connect it to your Windows computer, the adapter also supports native USB audio, allowing you to add your computer's audio to the HDMI output signal.
The DVI to HDMI adapter is easy to use. The adapter features plug-and-play installation, so you won't need to load or download any special software, ensuring a fast and easy installation. The adapter also features a small footprint, ensuring it discreetly blends into your desktop setup, unlike bulky DVI adapter boxes that take up a lot of desk space.
If you want to transmit video only, you can just use the DVI connection. If you want to transmit audio as well as video, you can also plug in the USB connector. With no external power adapter needed, you have everything that you need in one compact solution.
This adapter ensures that you're harnessing HD video quality from your DVI output, with support for resolutions up to 1080p.
  • Hassle-free setup
    The DVI to HDMI adapter is easy to use. The adapter features Plug and Play installation, so you won't need to load or download any special software, ensuring a fast and easy installation. The adapter also features a small footprint, ensuring it discreetly blends into your desktop setup. If you want to transmit video only, you can just use the DVI connection. If you want to transmit audio as well as video, you can also plug in the USB connector. With no external power adapter needed, you have everything, that you need, in one compact solution.
  • Crystal clear high-definition video
    This adapter ensures, that you're harnessing HD video quality from your DVI output, with support for high resolutions.
StarTech.com DVI to HDMI Video Adapter with USB Power and Audio - 1080p - video / audio adaptor - HDMI / DVI
Cable
Video / audio adaptor - HDMI / DVI
Connector
HDMI - female
Connector (Second End)
DVI-D - male
2 years warranty
Cable Type
Interface Supported
HDMI / DVI
Plated Connector
Gold
Connector
19 pin HDMI Type A - female
24+1 pin digital DVI - male
Plug and Play, FCC, RoHS, WEEE
C7CC StarTech.com 3m High Speed HDMI Cable - Ultra HD 4k x 2k HDMI Cable - HDMI to HDMI M/M In Stock £6.55
C7CC StarTech.com 2m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £4.20
C7CC StarTech.com 10m (33 ft) Active CL2 In-wall High Speed HDMI Cable - Ultra HD 4k x 2k HDMI Cable In Stock £34.15
Price Range Ex VAT: 0 - 50
