StarTech.com DVI DDC EDID Ghosting Emulator with EDID Copy
Quicklinx: 89Z3WS00 Mfr#: VSEDIDDVI
Select:
£56.53 ex VAT
£67.83 inc VAT
Copy or emulate Extended Display Identification (EDID) data for optimal display settings. The VSEDIDDVI DVI EDID Emulator enables you to capture and retain Extended Display Identification Data from a monitor, which can then be connected to the video signal source (video extender, KVM switch, etc.) to pass the EDID information and ensure the proper video settings are maintained.
EDID information contains important display settings such as maximum image size, color characteristics, factory pre-set timings, frequency range limits, etc., and since most video extender systems don't offer EDID communication between the source and remote display, the DVI EDID Emulator is a perfect workaround for ensuring the optimum signal is provided to the display to help prolong the life of your displays.
StarTech.com DVI DDC EDID Ghosting Emulator with EDID Copy - EDID reader / writer - DVI
Interface Type
DVI
5.2 cm x 8 cm x 2.2 cm
123 g
Digital Video Capture Resolution
1280 x 720, 1600 x 1200, 1024 x 768, 1280 x 1024, 1920 x 1440, 1920 x 1080, 2048 x 1152, 2560 x 1440, 2560 x 1600, 1920 x 1200, 1440 x 900, 1680 x 1050, 1600 x 900
Double Duration Circuit (DDC) technology
Interface Type
DVI
5.2 cm
8 cm
2.2 cm
123 g
Video
1 x display / video - DVI-Analog/Digital - 24+5 pin combined DVI , 1 x USB
Device Features
USB powered
0 - 80%
89Z3 StarTech.com 6 ft DVI-I Dual Link Digital Analog Monitor Cable M/M In Stock £8.06
89Z3 StarTech.com 6 ft DVI-D Dual Link Cable - M/M In Stock £6.62
89Z3 StarTech.com 10 ft DVI-D Dual Link Cable - M/M In Stock £10.60
Price Range Ex VAT: 50 - 100
