StarTech.com Dual USB C Dock - Windows - PD
Quicklinx: DBXXWS00 Mfr#: MST30C2HHPDU
Device Type: Laptop
Type: Docking Stations
Device Screen Size: [N/A]
Colour: Silver/Black
£148.45 ex VAT
£178.14 inc VAT
This dual-monitor USB-C dock has all the connections you need to turn your laptop into a full workstation, through one USB Type-C cable.
  • Connect one adapter to power your dock and laptop
    The dock powers and charges your laptop and peripherals. With only one power adapter connected to the dock, you reduce clutter at your workstation.
  • All the connections you need
    This full-featured dock offers USB 3.0 ports, a Gigabit Ethernet port, plus audio and microphone connections.
  • Fast, easy setup
    The dock is easy to set up, with automatic driver installation.
StarTech.com Dual Monitor USB C Docking Station with 60W Power Delivery for Windows Laptops, USB C to HDMI / DVI Dock, USB 3.1 Gen 1 Type C Dock with Charging, Thunderbolt 3 Compatible - 5-Port USB 3.0 Hub (MST30C2HHPDU) - docking station - USB-C / Thunderbolt 3 - 2 x HDMI - 1GbE
Docking station
Docking Interface
Video Interfaces
2 x HDMI
8 cm x 22 cm x 2.8 cm
133 g
United Kingdom, Europe
Gigabit Ethernet
Power adapter AC 120/230 V 60 Watt Power Provided
3-year warranty
Docking station
8 cm
22 cm
2.8 cm
133 g
Enclosure Colour
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, USB 1.1, USB 2.0, USB 3.0, USB 3.1
1 x USB-C - input - 24 pin USB-C , 1 x USB-C - output - 24 pin USB-C , 2 x display / video - HDMI output - 19 pin HDMI Type A , 4 x SuperSpeed USB 3.0 - output - 9 pin USB Type A , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x audio - output - mini-phone 3.5 mm 4-pole
1 x USB-C cable - external , 2 x HDMI-DVI adapter - external
Dual monitor support, 1 USB 3.0 fast charging port, full duplex support
FCC, RoHS, WEEE, RCM, USB Battery Charging Specification Rev. 1.2, USB Power Delivery 2.0, DisplayPort 1.2, UASP (USB Attached SCSI Protocol)
Power adapter
AC 120/230 V
Power Provided
60 Watt
Microsoft Windows 7 / 8 / 8.1 / 10
Limited warranty - 3 years
5 °C
35 °C
DBXX StarTech.com USB-C Multifunction Adapter In Stock £47.42
Device Type: Laptop
