StarTech.com Dual TV Cart - 37-60in Display
Quicklinx: GN9VWS00 Mfr#: STNDMTVDUO
Accessory Type: Mount
£412.80 ex VAT
£495.36 inc VAT
This Dual Mobile TV Stand enables you to create a rolling AV media center that is easy to move across classrooms, offices, boardrooms, meetings, or learning environments. For better stability and safety, the mobile cart was engineered with a large 1.22m x 0.71m base that will let you can mount two displays of 37" to 60" and up to 110lb/each in weight.
  • Fully Adaptable to your setup
    This mobile TV stand with mount will adapt to the different setups that you may encounter in your office space. You can adjust the height of your display from 1.2m to 1.68m from the center of the TV to the floor, and the included adjustment indicators allow you to perform precise adjustments for the ideal viewing height. Additionally, the height adjustment indicators make installation easier and enable you to note the preferred height for specific environments. You can also individually tilt the viewing angle within +5/-10° to best suit your environment and reduce glare. The included lockable casters allow to easily move the TV stand between locations.
  • Storage for your AV devices
    For increased portability and customization, this universal mobile cart offers two independently adjustable device shelves (webcam shelf and equipment shelf) that each support up to 11lb/5kg. The webcam shelf can be raised up to 2.37m, while the equipment shelf can be raised up to 0.90m from the floor.
  • Durable construction
    The heavy-duty dual TV stand's durable construction makes it ideal for commercial use, in environments with multiple users and frequent movement between areas. Built-in cable management keeps your cables organized and hidden from view. The STNDMTVDUO is backed for 2-years by StarTech.com, including free lifetime 24/5 multi-lingual technical assistance.
StarTech.com Dual TV Cart for 37-60in VESA TVs up to 110lb (50kg) each, Height Adjustable TV Mount, Mobile Display Cart w/ Webcam & Equipment Shelves, Lockable Casters, TV Cart on Wheels - Rolling TV Stand (STNDMTVDUO) cart - for 2 monitors / curved monitors
Cart
220 cm x 71 cm x 240 cm
Tilt
+5° to -10°
Lift
50 cm
Adjustments
Height, tilt, lift
43 kg
Recommended Use
Recommended Display Size
37"-60"
VESA Mounting Interface
200 x 200 mm, 200 x 300 mm, 200 x 400 mm, 300 x 200 mm, 300 x 300 mm, 400 x 200 mm, 400 x 300 mm, 400 x 400 mm, 600 x 200 mm, 600 x 300 mm, 600 x 400 mm
Max Load Weight
50 kg
Material
Aluminium, steel
Wheels Qty
4
Package Content
Base, left column, right column, DVD shelf, connecting plate, camera shelf, support bar, hex key, wrench, 4 x casters, 4 x M6x15 screws, 2 x universal plates, 2 handles, 2 x left adapter brackets, 2 x right adapter brackets, 2 x top covers, 2 x connectors, 2 x fixing plates, 2 x knobs, 2 x M6x25 button head screws, 2 x M6x25 screws, 2 x M4x6 screws, 2 x M6x25 hex head screws, 2 x M6x25 carriage screws, 2 x spacers, 2 x round washers, 3 x M4x6 flat head screws, 10 x M6x14 screws, 8 x M5x14 screws, 8 x M6x14 screws, 8 x M6x30 screws, 8 x M8x25 screws, 8 x M8x30 screws, 8 x M8x50 screws, 8 x rectangular washers, 16 x spacers (small), 16 x spacers (big)
220 cm
71 cm
240 cm
43 kg
Material
Aluminium, steel
Package Content
AV Furniture
Cart
Recommended Use
Shelf Qty
2
Cable Management
Integrated cable management
37"-60"
Tilt
+5° to -10°
Lift
50 cm
Adjustments
Height, tilt, lift
Max Load Weight
50 kg
Wheels Qty
4
Brakes Qty
4
Dimensions & Weight Details
Dimensions
Cart - width: 220 cm, depth: 71 cm, height: 240 cm , Cart base - width: 122 cm, depth: 71 cm
130 cm x 81 cm x 18 cm / 43 kg
GN9V StarTech.com SPDIF Digital Coaxial or Toslink Optical to Stereo RCA Audio Converter In Stock £32.94
GN9V StarTech.com 2m 6ft Premium HDMI 2.0 Cable In Stock £18.49
GN9V StarTech.com 10m CL2 Active HDMI Cable - 4K In Stock £81.45
