StarTech.com Dual SD Card Reader - UHS-II
Quicklinx: CFPXWS00 Mfr#: 2SD4FCRU3
Access any two SD cards simultaneously on your USB-enabled device, with this ultra-fast portable card reader. This portable USB 3.0 card reader gives you ultra-fast read and write access to two SD memory cards simultaneously, including SD (Secure Digital), SDHC (Secure Digital High Capacity) and SDXC (Secure Digital Extended Capacity) flash cards. It connects easily to the USB-A port on your tablet, laptop or desktop computer for wide compatibility. Among its advanced features, this high-performance card reader supports SD 4.0 and UHS II.
The USB 3.0 SD card reader/writer offers fast read and write access to two SD cards simultaneously, with support for the speed of USB 3.0 (also known as USB 3.1 Gen 1), up to 5Gbps. It's ideal for creative professionals, including photographers, videographers and graphic designers, who need ultra-fast access to SD cards to offload raw images or edit video or photos, and backup files quickly. It saves time and increases productivity in your daily workload, letting your transfer files quickly when working with multiple SD cards, out in the field or in the studio.
Compatible with SD 4.0, the dual card reader supports standard SD speeds as well as Ultra High Speed (UHS), available on some SDHC and SDXC cards. With SD 4.0 and UHS-II support, this product offers uncompromising read and write speeds, increasing the data transfer rate to 312 MB/s for high-speed file transfers. By supporting the faster speeds of UHS-II, the card reader saves you valuable time when offloading videos and high volumes of photos to your computer, and increases efficiency during editing and post-production.
With the dual card reader, you can transfer data to and from two different cards at the same time, saving you time in the studio or out in the field. The card reader supports all popular SD cards such as SDSC, SDHC and SDXC including UHS cards, and is backwards compatible with older SD card versions. By providing two separate slots and support for a wide range of SD cards, the dual card reader helps you overcome the challenges of working with multiple card readers to offload videos and photos.
The card reader will also support microSD and miniSD (with adapter) and MMCmobile, RS-MMC and MMCplus (with adapter).
With a small form-factor and integrated cable, the dual SD card reader is a highly portable solution for accessing your SD cards, on a laptop or desktop computer. The wrap-around USB-A cable lets you quickly connect to a computer or pack it up quickly when you're done using it, without carrying an additional cable with you. The external SD card reader is OS independent, with no driver or software installation required.
The card reader/writer connects easily to your laptop, tablet, or desktop computer and is USB powered, providing sufficient power for most applications. If you require additional power, you can simply connect the USB cable on your power source to the auxiliary Micro-B power port on the 2SD4FCRU3.
StarTech.com also offers this same card reader and writer with a USB Type-C connector (2SD4FCRU3C) to provide compatibility for those with a USB-C enabled tablet, smartphone, laptop or computer.
  • Ultra-fast performance for workflow efficiency
    The USB 3.0 SD card reader/writer offers fast read and write access to two SD cards simultaneously, with support for the speed of USB 3.0, up to 5Gbps. It's ideal for creative professionals, including photographers, videographers, and graphic designers, who need ultra-fast access to SD cards to offload raw images or edit video or photos, and quickly back up files. It saves time and increases productivity in your daily workload, letting your transfer files quickly when working with multiple SD cards, out in the field or in the studio.
  • Supports a wide range of SD cards
  • Designed for portability
    With a small form-factor and integrated cable, the dual SD card reader is a highly portable solution for accessing your SD cards on a laptop or desktop computer. The wrap-around USB Type-C cable lets you quickly connect to a computer or pack it up quickly when you're done using it, without carrying an additional cable with you. The external SD card reader is OS independent, with no driver or software installation required.
Startech Dual-Slot SD Card Reader/Writer - USB 3.0 - SD 4.0, UHS II - Portable SD/SDHC/SDXC Card Reader/Writer with UHS-II (2SD4FCRU3) - card reader - USB 3.0
Card reader - external
Supported Memory Cards
MultiMediaCard, SD Memory Card, SDHC Memory Card, SDXC Memory Card
Host Interface
USB 3.0
Host Interface
USB 3.0
6.95 cm
10.6 cm
1.35 cm
57 g
Memory Card
(max)
Additional Ports
1 x USB charge port
Required Ports
1 x 9 pin USB Type A
DC 5 V
FCC, RoHS, WEEE, RCM
CFPX StarTech.com 5 ft Desktop SuperSpeed USB 3.0 Extension Cable - A to A M/F In Stock £11.80
CFPX StarTech.com 1m Blue SuperSpeed USB 3.0 Extension Cable A to A - M/F In Stock £6.71
CFPX StarTech.com 1m Black SuperSpeed USB 3.0 Extension Cable A to A - M/F In Stock £6.71
CFPX StarTech.com 7 Port SuperSpeed USB 3.0 Hub - Desktop USB Hub with Power Adapter – Black In Stock £48.45
CFPX StarTech.com 2m USB 3.0 C Cable w/ PD (3A) In Stock £14.59
CFPX StarTech.com CFast Card Reader - USB 3.0 In Stock £22.38
CFPX StarTech.com USB 3.0 SD/microSD Card Reader In Stock £9.52
CFPX StarTech.com CFast Card Reader - USB-C In Stock £28.39
