StarTech.com Dual Port USB Car Charger – High Power (17 Watt / 3.4 Amp)
Quicklinx: 9KZTWS00 Mfr#: USB2PCARBK
Charge your tablet and your cell phone simultaneously, in your car. The USB2PCARBK Dual Port USB Car Charger features two USB 2.0 ports and works with any standard car AUX power outlet, enabling you to charge two mobile devices simultaneously while you commute for work or play.
With a 1A port for charging your Smartphone or iPhone, and a 2.4A port for charging your iPad or other tablet, you can always be sure you have the correct charge available for all your mobile devices. Having the second USB charge port available means you can charge two phones simultaneously and even make sure both you and your passenger are fully charged and ready to go. Plus, your passenger can charge and text, work or game while their device is charging.
StarTech.com Dual-port USB car charger - 17W/3.4A - black car power adapter - USB - 17 Watt
Car power adapter
42 g
Output Connector Type
Total 2: USB
12 - 24 V
Voltage Provided
5 V
Max Electric Current
3.4 A
Power Provided
17 Watt
P/N: USBLT1MW, USBLT1MWS, USBLT2MBR, USBLT2MW, USBLT30CMW, USBLTM1MBK, USBLTM1MWH, UUSBHAUB1RA, UUSBHAUB3, UUSBHAUB3LA, UUSBHAUB3RA, UUSBHAUB6IN, UUSBHAUB6RA
Car power adapter
Tablet, mobile phone
42 g
Enclosure Colour
12 - 24 V
Input Connectors
Automobile cigarette lighter
Input Connectors Qty
1
Voltage Provided
5 V
Output connectors
Total 2: 4 pin USB Type A
Power Provided
17 Watt
3.4 A
9KZT StarTech.com 2x USB Car Charger 24W / 4.8A In Stock £12.51
