StarTech.com Dual Port PCI Express Gigabit Ethernet PCIe Network Card Adapter - PoE/PSE
Quicklinx: 8GN3WS00 Mfr#: ST2000PEXPSE
Hurry, only 2 left in stock!
£128.32 ex VAT
£153.98 inc VAT
Add two Power-over-Ethernet Gigabit Ports to a PCI Express-enabled Computer. The ST2000PEXPSE Dual Port PoE NIC provides two 10/100/1000 Mbps PoE RJ45 ports that can provide up to 25.5W of power each, combining a network data connection and power on a single cable, for less clutter and convenient installations in remote locations.
This full/low profile Gigabit server adapter supports the IEEE 802.3at (Type 1 and 2) standard for a Power Sourcing Equipment (PSE) device, and can deliver 48V DC power to compliant Powered Devices (PD). This eliminates the need for a separate power source and cable for remote networked devices such as IP cameras, IP phones and wireless access points.
Suitable for any PCI Express-enabled client, server or workstation, this versatile PoE network adapter supports features such as Jumbo Frames, VLAN tagging and Wake on LAN (WOL).
StarTech.com Dual Port PCI Express Gigabit Ethernet Network Card Adapter - 2 Port PCIe NIC 10/100/100 Server Adapter with PoE PSE (ST2000PEXPSE) - network adapter - PCIe - Gigabit Ethernet x 2
Network adapter
Plug-in card
Interface (Bus) Type
PCI Express x1
Ports
6.8 cm x 19.5 cm x 1.9 cm
150 g
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
10Mb LAN, 100Mb LAN, 1GbE
Data Transfer Rate
1 Gbps
Realtek Semiconductor RTL8111E
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3at
Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Apple MacOS X 10.6 - 10.9, Microsoft Windows Server 2016, Microsoft Windows 2000/XP/Vista/7/8/8.1/10, Linux 2.4.x to 4.11.x LTS versions only, Microsoft Windows Server 2019
Network adapter
Plug-in card
PCI Express x1
Ports
Wired
Cabling Type
Data Transfer Rate
1 Gbps
Status Indicators
PoE, link/activity
Full duplex capability, PoE, auto-uplink (auto MDI/MDI-X)
Processor / Memory
2 x 1000Base-T (PoE) - RJ-45
Compatible Slots
1 x PCI Express x1
Low-profile bracket
FCC, RoHS
Software Included
Drivers & Utilities
6.8 cm
19.5 cm
1.9 cm
150 g
55 °C
5 - 95%
