Add two Power-over-Ethernet Gigabit Ports to a PCI Express-enabled Computer. The ST2000PEXPSE Dual Port PoE NIC provides two 10/100/1000 Mbps PoE RJ45 ports that can provide up to 25.5W of power each, combining a network data connection and power on a single cable, for less clutter and convenient installations in remote locations.
This full/low profile Gigabit server adapter supports the IEEE 802.3at (Type 1 and 2) standard for a Power Sourcing Equipment (PSE) device, and can deliver 48V DC power to compliant Powered Devices (PD). This eliminates the need for a separate power source and cable for remote networked devices such as IP cameras, IP phones and wireless access points.
Suitable for any PCI Express-enabled client, server or workstation, this versatile PoE network adapter supports features such as Jumbo Frames, VLAN tagging and Wake on LAN (WOL).
- StarTech.com Dual Port PCI Express Gigabit Ethernet Network Card Adapter - 2 Port PCIe NIC 10/100/100 Server Adapter with PoE PSE (ST2000PEXPSE) - network adapter - PCIe - Gigabit Ethernet x 2
- Network adapter
- Form Factor
- Plug-in card
- Interface (Bus) Type
- PCI Express x1
- Ports
- 6.8 cm x 19.5 cm x 1.9 cm
- 150 g
- Cabling Type
- Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
- Data Link Protocol
- 10Mb LAN, 100Mb LAN, 1GbE
- Data Transfer Rate
- 1 Gbps
- Processor
- Realtek Semiconductor RTL8111E
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3at
- System Requirements
- Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Apple MacOS X 10.6 - 10.9, Microsoft Windows Server 2016, Microsoft Windows 2000/XP/Vista/7/8/8.1/10, Linux 2.4.x to 4.11.x LTS versions only, Microsoft Windows Server 2019
- 2-year warranty
- Network adapter
- Form Factor
- Plug-in card
- PCI Express x1
- Ports
- Connectivity Technology
- Wired
- Cabling Type
- 1 Gbps
- Status Indicators
- PoE, link/activity
- Full duplex capability, PoE, auto-uplink (auto MDI/MDI-X)
Processor / Memory
- Processor
- 2 x 1000Base-T (PoE) - RJ-45
- Compatible Slots
- 1 x PCI Express x1
- Included Accessories
- Low-profile bracket
- FCC, RoHS
- Software Included
- Drivers & Utilities
- OS Required
- 6.8 cm
- 19.5 cm
- 1.9 cm
- 150 g
- Limited warranty - 2 years
- 0 °C
- 55 °C
- 5 - 95%
StarTech.com 1000ft Roll Blue Stranded Cat 6 Patch Cable | In Stock | £349.44 |
StarTech.com Mini PCI Express Gigabit Ethernet Network Adapter NIC Card | In Stock | £22.60 |
StarTech.com Dual Port PCI Express Gigabit Ethernet PCIe Network Card Adapter - PoE/PSE | In Stock | £122.02 |
StarTech.com Dual Port Gigabit PCI Express Server Network Adapter Card - PCIe NIC | In Stock | £80.15 |
StarTech.com 1 Port 2.5G PoE Network Card | In Stock | £88.25 |
StarTech.com 1-Port 2.5Gbps PoE Network PCIe Card | In Stock | £83.63 |
StarTech.com 2.5Gbps PoE Network Card | In Stock | £161.23 |
