StarTech.com Dual Port PCI Express (PCIe x4) Gigabit Ethernet Server Network Card - Intel i350 NIC
Quicklinx: 95QVWS00 Mfr#: ST2000SPEXI
Wired / Wireless: Wired
Protocol: Ethernet, Fast Ethernet, Gigabit Ethernet
Form Factor: Plug-in card
Compatibility: PC
Type: Network adapter
10 in stock
£103.74 ex VAT
£124.48 inc VAT
Add dual Gigabit Ethernet ports to a client, server or workstation through a PCI Express slot. The ST2000SPEXI PCI Express Dual Port Gigabit Network Card lets you add two gigabit Ethernet ports to a desktop computer through a single, four-lane (x4 or higher) PCI Express slot. Each port is fully compatible with IEEE 802.3/u/ab standards, for 10/100/1000 Mbps auto-negotiation.
This 2-port GbE network card is based on the high-performance Intel I350 chipset, which offers several advanced driver options including IEEE 802.3ad link aggregation / teaming support, enabling you to add additional bandwidth to your system. Support for Jumbo Frames, full-duplex operation and 802.1q VLAN tagging also aid in creating an efficient network configuration.
Also useful for virtualization applications or setting up a dual-homed host configuration, this dual-port network card lets you accommodate several complex network scenarios, to meet your business needs. For added versatility, the controller card is equipped with a standard profile bracket and includes a low-profile/half-height bracket for installation in small form-factor computers.
StarTech.com Dual Port PCI Express (PCIe x4) Gigabit Ethernet Server Adapter - 2 Port Network Card - Intel i350 NIC - GbE Network Card (ST2000SPEXI) - network adapter
Network adapter
Plug-in card
Interface (Bus) Type
PCI Express 2.1 x4
PCI Specification Revision
PCIe 2.1
Ports
Gigabit Ethernet x 2
6.7 cm x 12.1 cm x 1.9 cm
90 g
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
10Mb LAN, 100Mb LAN, GigE
Data Transfer Rate
1 Gbps
Network / Transport Protocol
TCP/IP, UDP/IP
Intel I350-AM2
IEEE 802.3, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3ad (LACP), IEEE 802.1as, IEEE 1588-2008
Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows 7 / 8 / 8.1 / 10, Microsoft Windows Server 2016, Linux 2.4.x to 4.11.x LTS versions only, Microsoft Windows Server 2019
Network adapter
Plug-in card
PCI Express 2.1 x4
PCIe 2.1
Ports
Wired
Cabling Type
Data Transfer Rate
1 Gbps
TCP/IP, UDP/IP
Status Indicators
Link/activity
Full duplex capability, wake on LAN (WOL), auto-uplink (auto MDI/MDI-X), Jumbo Frames support, teaming support, Large Send Offload (LSO), TCP Segmentation Offload (TSO), tagged VLAN, checksum offload support
Processor / Memory
Intel I350-AM2
2 x 1000Base-T - RJ-45
Low-profile bracket
FCC, RoHS
Software Included
Drivers & Utilities
6.7 cm
12.1 cm
1.9 cm
90 g
50 °C
5 - 85%
95QV StarTech.com 6 ft Cat 6 Blue Molded RJ45 UTP Gigabit Cat6 Patch Cable In Stock £3.36
95QV StarTech.com Dual Port PCI Express Gigabit Ethernet PCIe Network Card Adapter - PoE/PSE In Stock £103.74
95QV StarTech.com USB 3.0 to Dual Port Gigabit Ethernet Adapter NIC w/ USB Port In Stock £44.60
95QV StarTech.com Dual Port PCI Express (PCIe x4) Gigabit Ethernet Server Network Card - Intel i350 NIC In Stock £103.74
Protocol: Ethernet
Protocol: Fast Ethernet
Protocol: Gigabit Ethernet
Compatibility: PC
Price Range Ex VAT: 100 - 150
