StarTech.com Dual Port Gigabit PCI Express Server Network Adapter Card - PCIe NIC
Quicklinx: 9XDHWS00 Mfr#: ST1000SPEXD4
Wired / Wireless: Wired
Protocol: Ethernet, Fast Ethernet, Gigabit Ethernet
Form Factor: Plug-in card
Compatibility: Mac, PC
Type: Network adapter
More than 50 in stock
£63.09 ex VAT
£75.70 inc VAT
Add dual Gigabit Ethernet ports to a client, server or workstation through a PCI Express slot. The ST1000SPEXD4 PCI Express Dual-Port Gigabit Network Card lets you add two gigabit Ethernet ports to a client, server or workstation through a single PCIe slot. Each port provides 10/100/1000 Mbps capable Ethernet and is fully compatible with IEEE 802.3/u/ab standards.
Suitable for any standard PCI Express-enabled system, the 2-port Ethernet card supports full-duplex flow control for maximum data transfer speeds of up to 2000 Mbps - an ideal 2-port NIC for setting up dual-homed, or multi-homed host configurations providing added security to corporate networks.
The dual-port server adapter is compliant with the PCIe 2.0 standard and features support for Jumbo Frames and 802.1q VLAN tagging as well as Wake on LAN (WoL). The adapter includes an optional low-profile/half-height bracket that can be used for installation into a standard or small form-factor computer chassis.
StarTech.com Dual Port Gigabit PCI Express Server Network Adapter Card - network adapter
Network adapter
Plug-in card - low profile
Interface (Bus) Type
PCI Express x1
Ports
Gigabit Ethernet x 2
1.8 cm x 9.26 cm x 12 cm
54 g
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
10Mb LAN, 100Mb LAN, GigE
Data Transfer Rate
1 Gbps
1 x RTL8111E - Realtek Semiconductor
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x
Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Apple MacOS X 10.4 - 10.9, Microsoft Windows Server 2016, Microsoft Windows 2000/XP/Vista/7/8/8.1/10, Linux 2.4.x to 4.11.x LTS versions only, Microsoft Windows Server 2019
Network adapter
PCI Express x1
Ports
Wired
Cabling Type
Data Transfer Rate
1 Gbps
Status Indicators
Link/activity
Flow control, half duplex mode, full duplex mode, Jumbo Frames support, tagged VLAN
Processor / Memory
2 x 1000Base-T - RJ-45
Low-profile bracket
FCC, RoHS
Software Included
Drivers & Utilities
1.8 cm
9.26 cm
12 cm
54 g
70 °C
10 - 90%
9XDH StarTech.com 10' Cat5e Patch Cable Black In Stock £3.31
9XDH StarTech.com 15 ft Cat 6 Blue Molded RJ45 UTP Gigabit Cat6 Patch Cable In Stock £4.73
9XDH StarTech.com 10 ft Cat 6 Blue Molded RJ45 UTP Gigabit Cat6 Patch Cable In Stock £3.83
9XDH StarTech.com 10ft Blue Cat5 UTP Patch Cable In Stock £3.31
9XDH StarTech.com 6ft Blue Cat5e UTP Patch Cable In Stock £2.76
Protocol: Ethernet
Protocol: Fast Ethernet
Protocol: Gigabit Ethernet
Compatibility: Mac
Compatibility: PC
Price Range Ex VAT: 50 - 100
