StarTech.com Dual Port ExpressCard Gigabit Laptop Ethernet NIC Network Adapter Card
Quicklinx: 7NXRWS00 Mfr#: EC2000S
Wired / Wireless: Wired
Protocol: Gigabit Ethernet, Fast Ethernet, Ethernet
Form Factor: Plug-in module
Compatibility: PC, Mac
Type: Network adapter
£114.48 ex VAT
£137.37 inc VAT
The EC2000S 2-port Gigabit ExpressCard Ethernet Adapter adds 2 10/100/1000Mbps Ethernet ports to an ExpressCard-enabled laptop, or small form factor system, enabling you to connect to two separate physical networks simultaneously with dedicated bandwidth, or providing full dedicated bandwidth to virtual machines.
Supporting features such as NDIS5 checksum and large send offload for lower CPU utilization, Wake-on-LAN (WOL) and Remote Wake-up power management, jumbo frames and VLAN tagging, this ExpressCard Ethernet Adapter is ready to handle a wide variety of scenarios.
With a 34mm ExpressCard form factor, this compact and portable Gigabit Ethernet Adapter will fit in any ExpressCard-enabled system.
StarTech.com Dual Port ExpressCard Gigabit Laptop Ethernet NIC Network Adapter Card - network adapter - ExpressCard - Gigabit Ethernet x 2
Network adapter
Plug-in module
Interface (Bus) Type
ExpressCard/34
Ports
3.4 cm x 11.6 cm x 2.1 cm
150 g
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
10Mb LAN, 100Mb LAN, GigE
Data Transfer Rate
1 Gbps
Network / Transport Protocol
TCP/IP, UDP/IP
1 x Realtek Semiconductor RTL8111E
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3x
Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Apple MacOS X 10.6 - 10.9, Microsoft Windows Server 2016, Microsoft Windows 2000/XP/Vista/7/8/8.1/10, Linux 2.4.x to 4.11.x LTS versions only, Microsoft Windows Server 2019
Network adapter
Plug-in module
ExpressCard/34
Ports
Wired
Cabling Type
Data Transfer Rate
1 Gbps
TCP/IP, UDP/IP
Status Indicators
Port transmission speed, link/activity
Flow control, full duplex capability, remote Wake Up, hot swap module replacement, auto-negotiation, wake on LAN (WOL), auto-uplink (auto MDI/MDI-X), half duplex mode, Jumbo Frames support
Processor / Memory
2 x 1000Base-T - RJ-45
Compatible Slots
1 x ExpressCard/34
Plug and Play, FCC, RoHS
Software Included
Drivers & Utilities
3.4 cm
11.6 cm
2.1 cm
150 g
Limited warranty - lifetime
55 °C
5 - 95%
Protocol: Fast Ethernet
Protocol: Ethernet
Compatibility: PC
Compatibility: Mac
Stock Status: In stock
