Charge two iPad tablets simultaneously, in your car. Do you carpool to work and need to flip a coin to see who will get to charge their tablet on the way to the office? Do you need to charge your tablet and phone at the same time, so that they're both ready to use by the time you reach your destination?
Whatever your situation, this dual-port car charger offers a high-powered solution for charging two mobile devices simultaneously, while you're on the road.
You can charge any Lightning mobile device, including your iPad or iPhone, using this convenient 2-in-1 adapter. Plus, since the cable is attached directly to the charger, it won't ever get lost in your vehicle, or be just out of reach while you're driving.
The integrated USB port gives you the option to charge an additional Apple device, including a second iPad, at the same time.
Don't have a second Apple device? You can also charge Micro USB or Mini USB-enabled mobile devices with this adapter, such as a smartphone, tablet, or GPS using a USBHAUBMB1MW Mini/Micro USB cable.
No matter what you choose to charge, you can always be sure you have the correct charge available for all your mobile devices.
Each charge port provides 2.1A of power to assure that you have enough power to charge everything from a phone to a tablet. Whether you're charging two tablets at the same time or charging a phone and a tablet, you can be sure all of your mobile devices are ready when you need them.
- StarTech.com Dual Port Car Charger w/ Apple 8-pin Lightning Connector & USB Port - High Power (21W / 4.2A) - Dual iPad Car Charger (USBLT2PCARW) car power adapter - USB, Lightning - 21 Watt
- Product Type
- Car power adapter
- 50 g
- White
- Output Connector Type
- USB, Lightning
- Voltage Required
- 12 - 24 V
- Voltage Provided
- 5 V
- Max Electric Current
- 4.2 A
- Power Provided
- 21 Watt
- Cables
- Lightning cable
- 2-year warranty
- Product Type
- Car power adapter
- Designed For
- Portable player, tablet, mobile phone
- 50 g
- Enclosure Colour
- White
- Voltage Required
- 12 - 24 V
- Input Connectors
- Automobile cigarette lighter
- Input Connectors Qty
- 1
- Voltage Provided
- 5 V
- Output connectors
- 4 pin USB Type A, Apple Lightning
- Power Provided
- 21 Watt
- 4.2 A
- Cables Included
- Lightning cable
- Limited warranty - 2 years
StarTech.com Micro USB to Mini USB Adapter | In Stock | £4.55 |
StarTech.com Mini USB to Micro USB Adapter | In Stock | £3.67 |
StarTech.com 6in Micro USB Cable - A to Micro B | In Stock | £4.66 |
StarTech.com 6in Micro USB to Mini USB Adapter Cable M/F | In Stock | £6.06 |
StarTech.com 1m (3ft) White Apple 8-pin Lightning Connector to USB Cable for iPhone / iPod / iPad | In Stock | £14.44 |
StarTech.com 2m (6ft) Long White Apple 8-pin Lightning Connector to USB Cable for iPhone iPod iPad | In Stock | £15.00 |
StarTech.com 3m (10ft) Long White Apple 8-pin Lightning Connector to USB Cable for iPhone iPod iPad | In Stock | £17.53 |
StarTech.com 3ft Right Angle Micro-USB Cable | In Stock | £5.12 |
StarTech.com 6ft Right Angle Micro-USB Cable | In Stock | £6.17 |
StarTech.com 3ft Micro-USB Charging Cable | In Stock | £4.92 |
StarTech.com 3 ft Micro-USB Charging Cable | In Stock | £4.56 |
StarTech.com 6 ft Micro-USB Charging Cable | In Stock | £6.94 |
StarTech.com 2x USB Car Charger 24W / 4.8A | In Stock | £12.20 |
StarTech.com 0.5m Angled Micro USB Cable | In Stock | £4.45 |
