The Desk Mount for 2x Vertically Stacked Monitors by StarTech.com is designed to enhance your workspace with a robust and flexible mounting solution. This mounting kit can accommodate two LCD displays or curved LCD displays, ranging from 17 to 49 inches. Constructed from durable plastic and steel, it ensures a sturdy setup while providing integrated cable management to keep your workspace tidy. Its versatile adjustments allow for height, tilt, swivel, and rotation, accommodating a variety of viewing angles. With a maximum load weight of 32 kg, it supports your monitors securely. Additionally, this desk-mountable design features a quick release mechanism, making it easy to install and reposition the monitors as needed.
Sturdy construction
Made from high-quality plastic and steel, this mount ensures reliability and stability for your monitors. -
Flexible adjustments
Enjoy a wide range of adjustments including height, tilt, swivel, and rotation, allowing for optimal viewing angles. -
Integrated cable management
Keep cables organized and out of sight with the built-in cable management system, enhancing the overall aesthetic of your workspace. -
Heavy load capacity
This mount can support a maximum load weight of 32 kg, making it suitable for a variety of monitor setups. -
Multiple display configurations
Easily switch between portrait and landscape orientations to suit your work preferences and needs.
- StarTech.com Desk Mount For 2x Vertically Stacked Monitors, Dual 49", TAA mounting kit - for 2 LCD displays/ curved LCD displays - quick release - black - TAA Compliant
- Product Type
- Mounting kit - desk-mountable
- Mounting Components
- C-clamp 25-100 mm, pole assembly, pole cap, 2 VESA mount, 2 VESA plates, 2 support collars
- 92.2 cm x 21.4 cm x 92.2 cm
- Adjustable Height
- Up to 69.6 cm
- Tilt
- -90° to 90°
- Rotation
- -180° to 180°
- Swivel
- -90° to 90°
- Adjustments
- Height, tilt, swivel, rotation
- 7 kg
- Recommended Use
- 2 LCD displays/ curved LCD displays
- Recommended Display Size
- 17"-49" (ultrawide)
- VESA Mounting Interface
- 75 x 75 mm, 100 x 100 mm
- Max Load Weight
- 32 kg
- Material
- Steel, plastic
- Black
- TAA Compliant
- Package Content
- 8 x M4 x 10 mm screw, 8 x M4 x 16 mm screw, 8 x 3/8" x 1/2" screw, 8 x spacers, M3 hex key, M6 hex key, wrench
- 5-year warranty
- 92.2 cm
- 21.4 cm
- 92.2 cm
- Adjustable Height
- Up to 69.6 cm
- 7 kg
- Material
- Steel, plastic
- Black
- Package Content
AV Furniture
- Mounting kit
- Recommended Use
- Placing / Mounting
- Desk-mountable
- Cable Management
- Integrated cable management
- Tilt
- -90° to 90°
- Rotation
- -180° to 180°
- Swivel
- -90° to 90°
- Adjustments
- Max Load Weight
- 32 kg
- TAA Compliant
- Finish
- Powder coated
- Details
- Landscape orientation, portrait orientation
Dimensions & Weight Details
- Shipping Dimensions (WxDxH) / Weight
- 83.5 cm x 21.3 cm x 16 cm / 7.3 kg
- Limited warranty - 5 years
StarTech.com 27" Monitor Privacy Screen | In Stock | £96.04 |
StarTech.com 25" Monitor Privacy Screen | In Stock | £63.96 |
