StarTech.com Dual-Monitor Stand - Horizontal - For up to 24" Monitors - S
Quicklinx: FBZTWS00 Mfr#: ARMDUOSS
13 in stock
£72.08 ex VAT
£86.49 inc VAT
Increase your productivity and free up desk space with this dual-monitor stand. The free-standing mount lets you install two displays up to 24", side by side, on a single base that you can place in virtually any workspace. The silver finish adds a designer touch to your office decor.
Set up a dual-monitor workstation with this VESA monitor stand (75x75, 100x100 mm) to boost your productivity. Compare and edit files on two screens with ease. Rotate your monitors 360 degrees for portrait or landscape viewing.
Maximize the surface area on your desk with the twin monitor stand. Its crossbar design makes it easy to mount two flat-panel displays. The monitor stand features a low-profile flat back so you can position your displays against an office wall or cubicle wall to free up space.
The crossbar design of the dual-monitor stand keeps your monitors perfectly aligned for comfortable viewing. You can customize the positioning of your displays with +/-15 degree tilt. You can also adjust the height of the monitors along the pole, up to 15.9" (40.5 cm).
The robust steel and aluminum monitor stand provides a stable set-up for your workstation. The sturdy platform also allows flexible use as a temporary setup, for instance, to make presentations in the boardroom.
StarTech.com Dual Monitor Stand - Free Standing Desktop Pole Stand for 2x 24" VESA Mount Displays -Synchronized Height Adjustable - Silver (ARMDUOSS) - stand
Stand - desktop
95 cm x 18 cm x 41 cm
Tilt
-15° to 15°
Swivel
360°
Adjustments
6.2 kg
Recommended Use
2 monitors
Recommended Display Size
24"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
16 kg
Material
Plastic, aluminium, steel
Black, silver
5-year warranty
95 cm
18 cm
41 cm
6.2 kg
Material
Black, silver
AV Furniture
Stand
Recommended Use
2 monitors
Placing / Mounting
Desktop
Cable Management
Integrated cable management
24"
Tilt
-15° to 15°
Swivel
360°
Adjustments
Max Load Weight
16 kg
Dimensions & Weight Details
70.5 cm x 30 cm x 11.8 cm / 6.2 kg
Limited warranty - 5 years
Price Range Ex VAT: 50 - 100
