Increase your productivity and free up desk space with this dual-monitor stand. The free-standing mount lets you install two displays up to 24", side by side, on a single base that you can place in virtually any workspace. The silver finish adds a designer touch to your office decor.
Set up a dual-monitor workstation with this VESA monitor stand (75x75, 100x100 mm) to boost your productivity. Compare and edit files on two screens with ease. Rotate your monitors 360 degrees for portrait or landscape viewing.
Maximize the surface area on your desk with the twin monitor stand. Its crossbar design makes it easy to mount two flat-panel displays. The monitor stand features a low-profile flat back so you can position your displays against an office wall or cubicle wall to free up space.
The crossbar design of the dual-monitor stand keeps your monitors perfectly aligned for comfortable viewing. You can customize the positioning of your displays with +/-15 degree tilt. You can also adjust the height of the monitors along the pole, up to 15.9" (40.5 cm).
The robust steel and aluminum monitor stand provides a stable set-up for your workstation. The sturdy platform also allows flexible use as a temporary setup, for instance, to make presentations in the boardroom.
- StarTech.com Dual Monitor Stand, Ergonomic Free Standing Dual Monitor Desktop Stand for two 24" VESA Mount Displays, Synchronized Height Adjustable, Double Monitor Pole Mount, Silver - Double Monitor Holder (ARMDUOSS) stand - for 2 monitors - black, silver
- Product Type
- Stand - desktop
- 95 cm x 18 cm x 41 cm
- Tilt
- -15° to 15°
- Swivel
- 360°
- Adjustments
- 6.2 kg
- Recommended Use
- 2 monitors
- Recommended Display Size
- 24"
- VESA Mounting Interface
- 100 x 100 mm, 75 x 75 mm
- Max Load Weight
- 16 kg
- Material
- Plastic, aluminium, steel
- Black, silver
- 5-year warranty
- 95 cm
- 18 cm
- 41 cm
- 6.2 kg
- Material
- Black, silver
AV Furniture
- Stand
- Recommended Use
- 2 monitors
- Placing / Mounting
- Desktop
- Cable Management
- Integrated cable management
- 24"
- Tilt
- -15° to 15°
- Swivel
- 360°
- Adjustments
- Max Load Weight
- 16 kg
Dimensions & Weight Details
- Shipping Dimensions (WxDxH) / Weight
- 70.5 cm x 30 cm x 11.8 cm / 6.2 kg
- Limited warranty - 5 years
StarTech.com Dual Monitor Stand | In Stock | £82.12 |
StarTech.com Vertical Dual Monitor Stand | In Stock | £80.40 |
StarTech.com Thin Client Mount - VESA | In Stock | £23.04 |
StarTech.com Vertical Dual Monitor Stand | In Stock | £105.98 |
StarTech.com Dual Monitor Stand - Articulating - For Monitors up to 32" | In Stock | £134.82 |
StarTech.com 21.5in. Monitor Privacy Screen - Universal - Matte/Glossy | In Stock | £54.54 |
StarTech.com Slim Anti-Theft K-Slot Lock Plate Adapter for MacBook/Tablet/iPad/Phone/Laptop | In Stock | £7.52 |
