Mount two displays on your desk surface or through a grommet, with adjustable height and cable management. The ARMDUAL Articulating Dual Monitor Arm lets you mount two displays to your desk or table, with extension, tilt, pan, swivel, pivot and height adjustments.
The desk-mount monitor arm offers a wide range of motion on several axes, giving you the freedom to place your displays side-by-side, spread apart, back-to-back or anywhere in between. For viewing longer pages or blocks of code without scrolling, the dual arm also supports landscape to portrait display rotation for either monitor.
Mounting your displays on a dual monitor arm above the desk surface enables you to adjust your display height, position and viewing angles easily for an ergonomic work environment, with the added benefit of reclaiming valuable workspace on your desk.
Supporting 12 - 24" displays up to a maximum weight capacity of 30lbs (13.6kg) per arm, the dual arm monitor mount holds your displays with ease, and integrates a cable management channel to keep things neat. For added installation flexibility, the included mounting hardware can either clamp to the side of your desk / table or mount through a grommet hole, for a versatile dual-monitor mounting solution.
Versatile design
The adjustable arm design allows for a full range of motion, enabling monitors to be positioned at the optimal height and angle for user comfort. -
Integrated cable management
Neatly organizes cables to reduce clutter and improve the overall appearance of your workspace. -
Strong support
Holds monitors with a maximum weight of 13.6 kg, ensuring stability and reliability for dual display setups. -
Flexible mounting options
Can be mounted using a desk clamp or grommet, providing users with the ability to choose the best installation method for their work area. -
360-degree rotation
Allows for easy switching between portrait and landscape orientations, accommodating different viewing preferences.
- StarTech.com Desk Mount Dual Monitor Arm - Articulating - Supports Monitors 12" to 24" - Adjustable VESA Monitor Arm - Grommet or Desk Mount - Black (ARMDUAL) mounting kit - adjustable arm - for 2 LCD displays - black
- Product Type
- Mounting kit (adjustable arm) - desk-mountable
- Tilt
- -90° to 90°
- Pan
- -90° to 90°
- Rotation
- 360°
- Adjustments
- Height, pan, tilt, swivel, rotation
- 4 kg
- Recommended Use
- 2 LCD displays
- Recommended Display Size
- 12"-24"
- VESA Mounting Interface
- 100 x 100 mm, 75 x 75 mm
- Max Load Weight
- 13.6 kg
- Material
- Plastic, steel
- Black
- Package Content
- 8 x M4x12 screws, allen wrench (4mm), 8 x spacers, desk clamp, grommet plate, 2 x cable-management clips, allen wrench (2.5mm), DEK, 2 x cover plates, 8 x M4x25 screws, 2 x M6x12 screws, 2 x M6 washers, 4 x gasket cushions, allen wrench (6mm)
- 5-year warranty
- Designed For
- P/N: ACCSMNT, ARMSTS, ARMSTSLG, DK30A2DH, DK30C2DAGPD, DK30C2HAGPD, PXT101YUK, TB3DK2DPM2, TB3DK2DPPD, USB3SDOCKDD, USB3SDOCKHD, USB3SDOCKHDV
- 4 kg
- Material
- Plastic, steel
- Black
- Package Content
AV Furniture
- Mounting kit
- Design
- Adjustable arm
- Recommended Use
- 2 LCD displays
- Placing / Mounting
- Desk-mountable
- Cable Management
- Integrated cable management
- 12"-24"
- Tilt
- -90° to 90°
- Pan
- -90° to 90°
- Rotation
- 360°
- Adjustments
- Max Load Weight
- 13.6 kg
Dimensions & Weight Details
- Shipping Dimensions (WxDxH) / Weight
- 4.9 kg
- Limited warranty - 5 years
- Designed For
StarTech.com Universal USB 3.0 Laptop Docking Station Dual-Monitor HDMI DVI | In Stock | £68.82 |
StarTech.com Universal USB 3.0 Laptop Docking Station - Dual Video HDMI DVI VGA with Audio | In Stock | £65.95 |
StarTech.com StarStarTech.com Universal USB 3.0 Laptop Docking Station w/ Dual DVI Video | In Stock | £47.08 |
StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount | In Stock | £141.07 |
StarTech.com Universal USB 3.0 4K Laptop Docking Station w/ 4K DisplayPort | In Stock | £86.99 |
StarTech.com Sit-to-Stand Workstation | In Stock | £243.11 |
StarTech.com Monitor Mount - USB Passthrough | In Stock | £164.60 |
StarTech.com Dual Monitor Mount - Stackable | In Stock | £222.28 |
StarTech.com Dual Monitor Stand | In Stock | £83.12 |
StarTech.com Desk Mount Quad Monitor Arm | In Stock | £178.72 |
StarTech.com Vertical Dual Monitor Mount | In Stock | £70.27 |
StarTech.com Dual 4K Docking Station, Mac & Windows - USB-A & USB-C Dock, Dual 4K60 DP & HDMI | In Stock | £134.78 |
StarTech.com Thin Client Mount - VESA | In Stock | £23.55 |
StarTech.com Under Desk Keyboard Tray | In Stock | £53.93 |
StarTech.com USB-C Multiport Adapter Docking Station | In Stock | £124.67 |
StarTech.com Desk Mount Dual Monitor Arm -Articulating-Up to 27" Monitors | In Stock | £195.19 |
StarTech.com Desk Mount Dual Monitor Arm - Crossbar | In Stock | £100.16 |
StarTech.com Desk Mount Dual Monitor Arm - Dual Swivel Articulating | In Stock | £99.84 |
StarTech.com 21.5in. Monitor Privacy Screen - Universal - Matte/Glossy | In Stock | £51.28 |
StarTech.com 24in. Monitor Privacy Screen - Universal - Matte / Glossy | In Stock | £58.71 |
StarTech.com 27in. Monitor Privacy Screen - Universal - Matte / Glossy | In Stock | £75.65 |
StarTech.com Dual Desk Mount Monitor Arm - Built-in 2-port USB and 3.5 mm | In Stock | £164.68 |
StarTech.com Slim Anti-Theft K-Slot Lock Plate Adapter for MacBook/Tablet/iPad/Phone/Laptop | In Stock | £7.60 |
