StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount
Quicklinx: 9TV3WS00 Mfr#: ARMDUAL
Accessory Type: Bracket
More than 50 In Stock
£135.75 ex VAT
£162.90 inc VAT
Mount two displays on your desk surface or through a grommet, with adjustable height and cable management. The ARMDUAL Articulating Dual Monitor Arm lets you mount two displays to your desk or table, with extension, tilt, pan, swivel, pivot and height adjustments.
The desk-mount monitor arm offers a wide range of motion on several axes, giving you the freedom to place your displays side-by-side, spread apart, back-to-back or anywhere in between. For viewing longer pages or blocks of code without scrolling, the dual arm also supports landscape to portrait display rotation for either monitor.
Mounting your displays on a dual monitor arm above the desk surface enables you to adjust your display height, position and viewing angles easily for an ergonomic work environment, with the added benefit of reclaiming valuable workspace on your desk.
Supporting 12 - 24" displays up to a maximum weight capacity of 30lbs (13.6kg) per arm, the dual arm monitor mount holds your displays with ease, and integrates a cable management channel to keep things neat. For added installation flexibility, the included mounting hardware can either clamp to the side of your desk / table or mount through a grommet hole, for a versatile dual-monitor mounting solution.
  • Versatile design
    The adjustable arm design allows for a full range of motion, enabling monitors to be positioned at the optimal height and angle for user comfort.
  • Integrated cable management
    Neatly organizes cables to reduce clutter and improve the overall appearance of your workspace.
  • Strong support
    Holds monitors with a maximum weight of 13.6 kg, ensuring stability and reliability for dual display setups.
  • Flexible mounting options
    Can be mounted using a desk clamp or grommet, providing users with the ability to choose the best installation method for their work area.
  • 360-degree rotation
    Allows for easy switching between portrait and landscape orientations, accommodating different viewing preferences.
StarTech.com Desk Mount Dual Monitor Arm - Articulating - Supports Monitors 12" to 24" - Adjustable VESA Monitor Arm - Grommet or Desk Mount - Black (ARMDUAL) mounting kit - adjustable arm - for 2 LCD displays - black
Mounting kit (adjustable arm) - desk-mountable
Tilt
-90° to 90°
Pan
-90° to 90°
Rotation
360°
Adjustments
Height, pan, tilt, swivel, rotation
4 kg
Recommended Use
2 LCD displays
Recommended Display Size
12"-24"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
13.6 kg
Material
Plastic, steel
Package Content
8 x M4x12 screws, allen wrench (4mm), 8 x spacers, desk clamp, grommet plate, 2 x cable-management clips, allen wrench (2.5mm), DEK, 2 x cover plates, 8 x M4x25 screws, 2 x M6x12 screws, 2 x M6 washers, 4 x gasket cushions, allen wrench (6mm)
5-year warranty
P/N: ACCSMNT, ARMSTS, ARMSTSLG, DK30A2DH, DK30C2DAGPD, DK30C2HAGPD, PXT101YUK, TB3DK2DPM2, TB3DK2DPPD, USB3SDOCKDD, USB3SDOCKHD, USB3SDOCKHDV
4 kg
Material
Plastic, steel
Package Content
AV Furniture
Mounting kit
Design
Adjustable arm
Recommended Use
2 LCD displays
Placing / Mounting
Desk-mountable
Cable Management
12"-24"
Tilt
-90° to 90°
Pan
-90° to 90°
Rotation
360°
Adjustments
Max Load Weight
13.6 kg
Dimensions & Weight Details
4.9 kg
Limited warranty - 5 years
9TV3 StarTech.com Universal USB 3.0 Laptop Docking Station Dual-Monitor HDMI DVI In Stock £65.29
9TV3 StarTech.com Universal USB 3.0 Laptop Docking Station - Dual Video HDMI DVI VGA with Audio In Stock £62.58
9TV3 StarTech.com StarStarTech.com Universal USB 3.0 Laptop Docking Station w/ Dual DVI Video In Stock £47.08
9TV3 StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount In Stock £135.75
9TV3 StarTech.com Universal USB 3.0 4K Laptop Docking Station w/ 4K DisplayPort In Stock £82.53
9TV3 StarTech.com Sit-to-Stand Workstation In Stock £234.62
9TV3 StarTech.com Monitor Mount - USB Passthrough In Stock £157.69
9TV3 StarTech.com Dual Monitor Mount - Stackable In Stock £213.39
9TV3 StarTech.com Dual Monitor Stand In Stock £80.12
9TV3 StarTech.com Desk Mount Quad Monitor Arm In Stock £171.25
9TV3 StarTech.com Vertical Dual Monitor Mount In Stock £67.16
9TV3 StarTech.com Dual 4K Docking Station, Mac & Windows - USB-A & USB-C Dock, Dual 4K60 DP & HDMI In Stock £134.78
9TV3 StarTech.com Thin Client Mount - VESA In Stock £22.13
9TV3 StarTech.com Under Desk Keyboard Tray In Stock £52.06
9TV3 StarTech.com USB-C Multiport Adapter Docking Station In Stock £118.27
9TV3 StarTech.com Desk Mount Dual Monitor Arm -Articulating-Up to 27" Monitors In Stock £187.20
9TV3 StarTech.com Desk Mount Dual Monitor Arm - Crossbar In Stock £96.45
9TV3 StarTech.com Desk Mount Dual Monitor Arm - Dual Swivel Articulating In Stock £95.58
9TV3 StarTech.com 21.5in. Monitor Privacy Screen - Universal - Matte/Glossy In Stock £50.12
9TV3 StarTech.com 24in. Monitor Privacy Screen - Universal - Matte / Glossy In Stock £58.71
9TV3 StarTech.com 27in. Monitor Privacy Screen - Universal - Matte / Glossy In Stock £75.65
9TV3 StarTech.com Dual Desk Mount Monitor Arm - Built-in 2-port USB and 3.5 mm In Stock £157.78
9TV3 StarTech.com Slim Anti-Theft K-Slot Lock Plate Adapter for MacBook/Tablet/iPad/Phone/Laptop In Stock £7.34
