StarTech.com Dual-Monitor DP 1.4 KVM Switch
Quicklinx: HSVSWS00 Mfr#: P2CDD143-KVM-SWITCH
Type: KVM / audio / USB switch
Connectivity: KVM
Ports: 2
Hurry, only 1 left in stock!
£399.05 ex VAT
£478.86 inc VAT
The StarTech.com 2-Port Dual-Monitor DisplayPort KVM Switch is designed to meet the needs of users requiring high-resolution support and advanced connectivity. This KVM switch allows for seamless switching between systems, supporting 8K resolution at 60 Hz and 4K resolution at 144 Hz, making it suitable for professionals and gamers. With 2x USB 3.2 Gen 2 ports and 4x USB HID ports, it offers ample connectivity for a wide range of devices, ensuring high-speed data transfer and efficient performance.
The device is built to last, featuring a robust metal housing and comprehensive ESD protection up to 8 kV. It also includes features such as hotkey switching, a built-in buzzer for audible alerts, and EMI protection, ensuring a secure and high-quality connection. With support for HDR and Display Stream Compression (DSC), it delivers enhanced image quality, making every detail come to life. Whether for work or play, this KVM switch is designed to provide a seamless, high-quality experience.
  • Enhanced visual experience
    Experience high visual quality with support for 8K resolution at 60 Hz and 4K resolution at 144 Hz. The DisplayPort 1.4 compliance ensures high-bandwidth video transmission, enabling vivid, detailed images and smoother motion for an immersive viewing experience.
  • Advanced connectivity options
    Equipped with 2x USB 3.2 Gen 2 ports and 4x USB HID ports, this KVM switch offers high-speed data transfer rates up to 10 Gbps. Whether connecting storage devices, peripherals, or gaming consoles, users enjoy efficient, lag-free performance.
  • Seamless control and durability
    Featuring hotkey switching and a built-in buzzer for audible alerts, this KVM switch allows for effortless control between systems without sacrificing desk space. The metal housing and ESD protection up to 8 kV ensure long-term reliability and durability in various environments.
  • Comprehensive protection
    Designed with EMI protection, 10-bit Deep Color, and 4:4:4 chroma subsampling support, this device ensures a secure and high-quality connection. HDR support and Display Stream Compression (DSC) further enhance image quality, making it ideal for professional and gaming setups.
  • Efficient power and operation
    The external power adapter provides a stable power supply with a nominal voltage of AC 120/230 V and a power consumption of 36 W. With an MTBF of 168,000 hours, users can trust in the device's efficiency and longevity for continuous operation.
StarTech.com 2-Port Dual-Monitor DisplayPort KVM Switch, 8K 60Hz / 4K 144Hz, DP 1.4, 2x USB 10Gbps Ports, 4x USB HID Ports, Hotkey Switching, TAA Compliant - KVM / audio / USB switch - 2 ports - TAA Compliant
Subtype
KVM
Ports
2 x KVM / audio / USB
KVM Users Qty
1 local user
4K resolution support, metal housing, 8KV ESD Protector (air-gap discharge), HDR support, 10-bit Deep Colour support, 6KV ESD Protector (contact discharge), 4:4:4 chroma subsampling support, built-in buzzer, push button, DSC, LED status indicator, hotkeys, wide screen supported, EMI protection
USB 1.1, USB 3.2 Gen 2
AC 100-240 V 1 A
16 cm x 10 cm x 6 cm
800 g
Australia, New Zealand, North America, United Kingdom, Europe
TAA Compliant
Enclosure Type
Desktop
Subtype
KVM
Ports
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
USB
Max Resolution
8K @ 60 Hz
4K resolution support, metal housing, 8KV ESD Protector (air-gap discharge), HDR support, 10-bit Deep Colour support, 6KV ESD Protector (contact discharge), 4:4:4 chroma subsampling support, built-in buzzer, push button, DSC, LED status indicator, hotkeys, wide screen supported, EMI protection, Auto Scan mode
1 x Genesys Logic GL3590
Status Indicators
Port status
2 x DisplayPort output console , 2 x USB 3.2 Gen 2 Type A console , 4 x USB 1.1 Type A console , 1 x audio output mini-jack console , 4 x DisplayPort input host , 2 x audio mini-jack host , 2 x USB 3.2 Gen 2 Type C host
External power adapter
Power Provided
DC 12 V - 3 A
AC 100-240 V
Electric Current Required
1 A
36 Watt
2 x USB-C to USB-A cable
MTBF
168,000 hours
RoHS, WEEE, DisplayPort 1.4
TAA Compliant
16 cm
10 cm
6 cm
800 g
Shipping Width
23.8 cm
Shipping Depth
18.4 cm
Shipping Height
8.9 cm
Shipping Weight
1.4 kg
0 - 80% RH (non-condensing)
Min Storage Temperature
-10 °C
Max Storage Temperature
60 °C
HSVS StarTech.com 6 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £3.97
HSVS StarTech.com 3ft DisplayPort 1.4 8K 60Hz In Stock £14.40
HSVS StarTech.com 6ft DisplayPort 1.4 8K 60Hz In Stock £14.98
HSVS StarTech.com 10ft DisplayPort 1.4 8K 60Hz In Stock £21.09
HSVS StarTech.com 2-Port DisplayPort KVM Switch In Stock £300.12
Connectivity: KVM
Ports: 2
