This crossbar monitor desk mount is designed to support up to two 27-inch displays, creating an ergonomic multi-monitor setup that provides an extensive viewing area for productivity. The built-in handle enables moving all monitors simultaneously, while the spring-assisted arm allows multiple adjustments to suit different ergonomic needs. The mechanical spring arm enables a toolless height adjustment range of 7.9-20.8in (20.2-52.9cm)) with effortless one-touch motion. The maximum arm extension is 22.6in (57.4cm) and the total weight capacity is 33lb (15kg). This monitor mount is ideal for bezel-less or slim bezel displays, creating a more extensive and seamless viewing experience that enhances multitasking and productivity. The VESA mounts can slide along the crossbar, allowing for further adjustments. The monitors' VESA mounts support +/-30° swivel, +65°/-15° tilt, and 360° screen rotation for portrait or landscape orientation. The computer monitor mount is backed for 10 years. The arms feature a cable management channel along the underside to keep cables out of sight, reducing clutter and contributing to a tidy setup.
Height Adjustment with One Smooth Motion
The mechanical spring arm enables toolless height adjustment of up to 12.9in (32.7cm) with effortless one-touch motion. The maximum arm extension is 22.6in (57.4cm) and a total weigh capacity of 33lb (15kg). -
Visual Experience
This monitor mount is ideal for bezel-less or slim bezel displays, creating a more extensive and seamless viewing experience that enhances multitasking and productivity. The VESA mounts can slide along the crossbar, allowing for further adjustments. -
Range of Motion
The monitors' VESA mounts enable support +/-15° swivel, +65/-15° tilt, and 360° screen rotation for portrait/landscape orientation. -
Cable Management
To maintain an organized workspace, the arms feature a cable management channel along the underside to keep cables out of sight, reducing clutter and contributing to a tidy setup.
- StarTech.com Desk Mount Dual Monitor Arm w/ Crossbar, Up To 27" Displays mounting kit - articulating, mechanical spring - for 2 LCD displays - black - TAA Compliant
- Product Type
- Mounting kit (articulating, mechanical spring) - desk-mountable
- Adjustable Depth
- 10.4-63 cm
- Adjustable Height
- 20.2-52.9 cm
- Tilt
- -15° to 5°
- Rotation
- 360°
- Swivel
- -180° to 180°
- Adjustments
- Height, tilt, swivel, rotation, pivot
- Recommended Use
- 2 LCD displays
- Recommended Display Size
- 17"-27"
- VESA Mounting Interface
- 100 x 100 mm, 75 x 75 mm
- Max Load Weight
- 30 kg
- Material
- Steel, plastic
- Black
- TAA Compliant
- Package Content
- Monitor arm, 2 x VESA monitor mount, EVA cushion, 8 x VESA screws, cable clip, M3 hex key, M6 hex key, crossbar, 2 x crossbar endcaps, 4 x M6x12 screws, 5 x M6 cap nuts, grab handle
- 10 years warranty
- Adjustable Depth
- 10.4-63 cm
- Adjustable Height
- 20.2-52.9 cm
- Material
- Steel, plastic
- Black
- Package Content
AV Furniture
- Mounting kit
- Design
- Articulating, mechanical spring
- Recommended Use
- 2 LCD displays
- Placing / Mounting
- Desk-mountable
- Cable Management
- Cable management channel
- 17"-27"
- Tilt
- -15° to 5°
- Rotation
- 360°
- Swivel
- -180° to 180°
- Adjustments
- Max Load Weight
- 30 kg
- TAA Compliant
- Assembly Required
Dimensions & Weight Details
- Shipping Dimensions (WxDxH) / Weight
- 80 cm x 35.2 cm x 17.1 cm / 6.3 kg
- Limited warranty - 10 years
StarTech.com 27in. Monitor Privacy Screen - Universal - Matte / Glossy | In Stock | £77.54 |
StarTech.com 24" Monitor Privacy Screen | In Stock | £79.81 |
StarTech.com 27" Monitor Privacy Screen | In Stock | £103.98 |
StarTech.com 25" Monitor Privacy Screen | In Stock | £73.04 |
StarTech.com Desk Mount Monitor Arm/Max 32" | In Stock | £161.49 |
