StarTech.com Dual Monitor Arm - Synced Height Adjustment - Grommet/Desk Clamp
Quicklinx: FVKQWS00 Mfr#: ARMSLMBARDUO
46 In Stock
£120.35 ex VAT
£144.42 inc VAT
Adjustable Dual Monitor Mount Synced Height Adjustment Easy-Grip Handle. This Dual Monitor Arm lets you mount two 17" to 32" VESA mount monitors, each weighing up to 17.6 lb. (8 kg), onto a single low-profile base. It gives you flexible desk-clamp or grommet-hole mounting, letting you save space while creating an ergonomic workspace in any office environment.
Free Up Desk Space
With a stable crossbar design, the adjustable height dual monitor stand lets you create more usable work space by mounting your monitors side by side on a single base.
Optimal Viewing
The computer screen stand features one-touch height adjustment. The smooth +/- 10° tilt motion and +/- 90° swivel make it easy to find the optimal viewing angle. You can also rotate each display 180° for portrait or landscape viewing and laterally adjusted along the crossbar length.
Flexible Installation
The adjustable dual monitor mount is easy to install, with the desk-clamp or grommet mount (hardware included). Integrated cable management keeps your workspace organized. It works well with most desks, including sit-stand workstations.
The Choice of IT Pros Since 1985
StarTech.com conducts thorough compatibility and performance testing on all our products to ensure we are meeting or exceeding industry standards and providing high-quality products to IT Professionals. Our local StarTech.com Technical Advisors have broad product expertise and work directly with our StarTech.com Engineers to provide support for our customers both pre and post-sales.
ARMSLMBARDUO is backed by a 5-year StarTech.com warranty and free lifetime technical support.
  • Free up desk space
  • Optimal viewing
  • Flexible installation
    The adjustable dual monitor mount is easy to install, with the desk-clamp or grommet mount. Integrated cable management keeps your workspace organized. It works well with most desks, including sit-stand workstations.
StarTech.com Desk Mount Dual Monitor Arm, Ergonomic Dual Monitor VESA Mount for 32" 17.6lbs (8kg) Displays, Crossbar Handle for Synchronized Full Motion, Height Adjustable, C-Clamp/Grommet - Small Footprint Design (ARMSLMBARDUO) mounting kit - adjustable arm - for 2 monitors - black
Mounting kit (adjustable arm) - desk-mountable
56.9 cm x 83.2 cm x 59.5 cm
Tilt
-10° to 10°
Rotation
-180° to 180°
Swivel
-90° to 90°
Adjustments
Height, tilt, swivel, rotation
7.3 kg
Recommended Use
2 monitors
Recommended Display Size
17"-32"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
8 kg
Material
Heavy duty steel
Package Content
8 x M4x12 screws, hex key (4mm), hex key (3mm), grommet plate, hex key (6mm), 8 x M5x12 screws, 4 x countersunk screws, grommet screw, 2 x flat head hex screws, 4 x button head hex screws
5-year warranty
56.9 cm
83.2 cm
59.5 cm
7.3 kg
Material
Heavy duty steel
Package Content
AV Furniture
Mounting kit
Design
Adjustable arm
Recommended Use
2 monitors
Placing / Mounting
Desk-mountable
Cable Management
17"-32"
Tilt
-10° to 10°
Rotation
-180° to 180°
Swivel
-90° to 90°
Adjustments
Max Load Weight
8 kg
Dimensions & Weight Details
22.5 cm x 89.5 cm x 15 cm / 8.8 kg
Limited warranty - 5 years
FVKQ StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount In Stock £139.14
FVKQ StarTech.com Monitor Mount - USB Passthrough In Stock £161.64
FVKQ StarTech.com Dual Monitor Mount - Stackable In Stock £217.58
FVKQ StarTech.com Desk Mount Dual Monitor Arm -Articulating-Up to 27" Monitors In Stock £191.88
FVKQ StarTech.com Desk Mount Dual Monitor Arm - Crossbar In Stock £98.86
FVKQ StarTech.com Desk Mount Dual Monitor Arm - Dual Swivel Articulating In Stock £97.96
FVKQ StarTech.com Dual Desk Mount Monitor Arm - Built-in 2-port USB and 3.5 mm In Stock £191.34
FVKQ StarTech.com Desk Mount Monitor Arm/Max 32" In Stock £161.49
FVKQ StarTech.com Dual Monitor Desk Mount In Stock £208.89
FVKQ StarTech.com Six-Monitor Desk Mount/Max 32" In Stock £277.24
