Customized Boardroom Table Solution For Adding Power, Charging, A/V, and Laptop Docking Modules. Looking for connectivity right at your fingertips in a boardroom, huddle space, or classroom? The dual-module conference-table connectivity box is a customizable solution that lets you design unique connectivity applications.
Customize to Your Exact Needs
Combine any two StarTech.com connectivity modules (sold separately) with the dual-module architectural connectivity box, to provide a solution that meets the exact needs of your space. Each module is interchangeable and provides easy-to-use solutions for connecting laptops and other devices.
StarTech.com connectivity modules let you:
Add AC power and USB outlets for charging your devices (MOD4POWERNA)
Dock your laptop with boardroom peripherals, webcams, speakers, mics, and displays (MOD4DOCKACPD)
Connect in-room A/V equipment to laptops, Chromebook notebooks, and 2-in-1 laptops (MOD4AVHD, MOD4AVHDBT)
Declutter your space with cable organizers (MOD4CABLEH)
Easy, Stylish and Clean Installation
Design a practical and stylish solution that impresses your visitors and facilitates their needs. The connectivity box features a black aluminum finish that complements your table and your peripherals. Plus, the lid closes flush with the table's surface to conceal connection points. The connectivity box is easy to install in a table or desk.
Keep Cables Untangled and Out of Sight
The connectivity box's built-in cable manager keeps cables easily accessible, free from tangles, and out of sight.
BOX4MODULE is backed by a StarTech.com 2-year warranty and free lifetime technical support.
Combine any two StarTech.com connectivity modules (sold separately) with the dual-module architectural connectivity box, to provide a solution that meets the exact needs of your space. Each module is interchangeable and provides easy-to-use solutions for connecting laptops and other devices. StarTech.com connectivity modules let you: • Add AC power and USB outlets for charging your devices (MOD4POWERNA) • Dock your laptop with boardroom peripherals, webcams, speakers, mics, and displays (MOD4DOCKACPD) • Connect in-room A/V equipment to laptops, Chromebook notebooks, and 2-in-1 laptops (MOD4AVHD, MOD4AVHDBT) • Declutter your space with cable organizers (MOD4CABLEH) -
Design a practical and stylish solution that impresses your visitors and facilitates their needs. The connectivity box features a black aluminum finish that complements your table and your peripherals. Plus, the lid closes flush with the table's surface to conceal connection points. The connectivity box is easy to install in a table or desk. -
The connectivity box's built-in cable manager keeps cables easily accessible, free from tangles, and out of sight. BOX4MODULE is backed by a StarTech.com 2-year warranty and free lifetime technical support.
- StarTech.com Dual-Module Conference Table Connectivity Box-Customizable - mounting plate
- Product Type
- Mounting plate
- Package Content
- 2 wing fasteners, die-cut outline, lacing bar, 4 lacing bar screws (M4 x 4mm), cable management bracket, 2 cable management top plates, small cable bushing, large cable bushing, 4 cable management plate screws, 4 cable management bracket mounting screws
- 31.8 cm x 11.3 cm x 16.8 cm
- 1.6 kg
- Product Material
- Aluminium, steel
- Black
- 2-year warranty
- Product Type
- Mounting plate
- Package Content
- Product Material
- Aluminium, steel
- 31.8 cm
- 11.3 cm
- 16.8 cm
- 1.6 kg
- Enclosure Colour
- Black
- Shipping Weight
- 1.8 kg
- Limited warranty - 2 years
