StarTech.com Dual M.2 to SATA Adapter, RAID
Quicklinx: D6QZWS00 Mfr#: S322M225R
£31.98 ex VAT
£38.37 inc VAT
Create high-performance storage with configurable RAID, by installing two M.2 SATA SSDs into a 2.5" SATA interface. Boost your system performance by enhancing the capacity, speed and security of your data storage. This two-drive M.2 to SATA adapter lets you install two M.2 SATA drives instead of a SATA platter drive, in a single 2.5" drive bay, and increase your storage options by configuring a powerful RAID array.
The dual M.2 to SATA adapter supports multiple RAID modes, including RAID 0, 1, or spanning, helping you to achieve greater SSD capacity or data redundancy, depending on your selected RAID mode. The SSD adapter also supports non-RAID operation (JBOD) when paired with a port-multiplying SATA controller, so both drives can be used independently of one another.
The M.2 SATA SSD adapter lets you utilize the full potential of your SATA III controller. Using M.2 SATA SSDs in place of a platter drive reduces your data transfer bottlenecks, giving you file transfer speeds of up to 6Gbps.
The M.2 NGFF SATA RAID adapter also provides TRIM support to enhance the stability and performance of your M.2 NGFF SSDs.
This open-frame adapter is easy to install as it comes with all the necessary installation hardware and doesn't require any extra software or drivers, to get you up and running quickly.
  • High performance
    Create a high-performance storage solution by installing up to two M.2 SATA SSDs into a 2.5" SATA adapter with RAID support for JBOD, SPAN, RAID 0, and RAID 1.
  • Hassle-free setup
    Open-frame steel mounting bracket with 2.5" SATA form factor fits in any 2.5" SATA bay that supports 7mm tall 2.5" drives. Easy to install with all necessary hardware included.
  • Wide compatibility
    Supports B & B+M key SATA M.2 SSDs in 2230/2242/2260/2280 form factors. Supports SATA I, II, and III (up to 6 Gbps) TRIM, and SMART. M & B+M key NVMe or AHCI PCI-e M.2 SSDs not supported (only SATA supported).
  • TRIM support
    TRIM support enhances the stability and performance of your M.2 SSDs plus it provides SMART support. TRIM supported in JBOD and RAID 1, SMART only supported in JBOD.
StarTech.com M.2 to SATA Adapter - Dual Slot - for 2.5in Drive Bay - RAID - M.2 SSD - M.2 Adapter - M.2 SSD Adapter (S322M225R) - storage controller (RAID) - M.2 Card - SATA 6Gb/s
Storage controller (RAID) - internal
Bus Type
SATA 6Gb/s
Red
Compatible Bay
1 2.5"
Hard Drive Form Factor Compatibility
M.2
M.2 Card
Data Transfer Rate
6 GBps
Supported Devices
Disk array (RAID), solid state drive
Max Storage Devices Qty
2
RAID Level
RAID 0, RAID 1, JBOD, BIG
7 cm x 10 cm x 0.7 cm
41 g
M.2
Host Bus
SATA 6Gb/s
Red
Storage Controller
M.2 Card
Data Transfer Rate
6 GBps
Supported Devices
2
RAID Level
ASMedia ASM1092R
2 x M.2 Card - M.2 Card
1 x SATA 6Gb/s - 22 pin Serial ATA
Compatible Bay
1 x internal 2.5"
4 x screws, 2 sets of drive-mounting hardware
S.M.A.R.T. support, TRIM support
FCC, RoHS, WEEE
7 cm
10 cm
0.7 cm
41 g
5 °C
50 °C
15 - 90%
D6QZ StarTech.com 24" Serial ATA Cable In Stock £5.28
D6QZ StarTech.com 18" Serial ATA Cable w/R Angle In Stock £5.00
D6QZ StarTech.com 18in SATA Serial ATA Data and Power Combo Cable In Stock £5.78
D6QZ StarTech.com 18in SATA Serial ATA Cable In Stock £2.50
D6QZ StarTech.com 12in LP4 to 2x SATA Power Y Cable Adapter In Stock £4.48
D6QZ StarTech.com 24in SATA to Right Angle SATA Serial ATA Cable In Stock £5.50
D6QZ StarTech.com 12in Latching SATA Cable In Stock £6.16
D6QZ StarTech.com 12in SATA Serial ATA Cable In Stock £5.00
D6QZ StarTech.com 6in SATA to LP4 Power Cable Adapter - F/M In Stock £6.06
D6QZ StarTech.com 6in SATA to Left Angle SATA Serial ATA Cable In Stock £3.93
D6QZ StarTech.com 2.5in SATA to Mini SATA SSD Adapter Enclosure In Stock £29.96
D6QZ StarTech.com Dual 2.5" to 3.5" HDD Bracket for SATA Hard Drives - 2 Drive 2.5" to 3.5" Bracket In Stock £7.24
D6QZ StarTech.com mSATA SSD to 2.5in SATA Adapter Converter In Stock £18.13
D6QZ StarTech.com Dual mSATA SSD to 2.5" SATA RAID Adapter Converter In Stock £14.65
D6QZ StarTech.com 18in Right Angle SATA Cable In Stock £4.34
