StarTech.com Dual HDMI over CAT6 Extender
Quicklinx: DV1KWS00 Mfr#: ST222HDBT
Extend two HDMI signals to distances up to 295 ft. (90m) over a single CAT5 or CAT6 cable. This HDMI over CAT6 extender lets you extend two HDMI sources up to 90 m (295 ft.), to individual HDMI displays over a single CAT6 cable. Designed for a simple, tidy setup, the extender also supports bi-directional IR control for added flexibility.
Reduce the need for additional equipment and cables, by extending two HDMI connections with a single CAT6 cable. Running only one cable can save cost on installation or enable you to extend two HDMI signals using an existing cable run. You can also use this 1080p HDMI extender to run separate video signals to the same display, for mission critical digital signage applications where if one signal goes down, the other can easily be swapped in it's place.
With bi-directional IR control, you can control your devices from either end of the extension, such as a Blu-ray player and laptop on one end and two TV displays on the other. The extender includes an IR kit with discreet dongles that easily connect to both your transmitter and receiver, enabling you to remotely control any device you choose from either side of your extension.
The simplicity of one-cable setup avoids the hassle of running multiple cables, while also reducing potential failure points. The included mounting hardware offers professional mounting options ideal for public spaces such as offices or auditoriums.
StarTech.com Dual HDMI over CAT5e / CAT6 Extender - 1080p over CAT6 or CAT5e - Up to 295 ft. (90m) (ST222HDBT) - video/audio/infrared extender - HDMI - TAA Compliant
Video/audio/infrared extender
External
Australia, Japan, New Zealand, United Kingdom, Europe, North Asia
HDMI
Transmission Medium
CAT 5e/6
Max Transfer Distance
90 m
AC 120/230 V
13 cm x 15.8 cm x 4.3 cm
200 g
TAA Compliant
External
Wired
HDMI
90 m
Status Indicators
Link OK, status
7.1 channel audio support
2 x HDMI (input) - 19 pin HDMI Type A female , 2 x HDMI (output) - 19 pin HDMI Type A female , 2 x IR (input) - mini jack female , 2 x IR (output) - mini jack female , 1 x SPDIF (input) - TOSLINK female , 1 x SPDIF (output) - TOSLINK female , 1 x microphone (input) - mini jack female , 1 x microphone (output) - mini jack female , 1 x headphones (input) - mini jack female , 1 x headphones (output) - mini jack female , 2 x serial - DB-9 male
IR receiver, IR transmitter, 8 rubber feet
1 x network cable
Mounting Kit
Included
FCC, RoHS
TAA Compliant
External power adapter
Installed Qty
1
AC 120/230 V
13 cm
15.8 cm
4.3 cm
200 g
Shipping Weight
256 g
DV1K StarTech.com 10 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £4.80
DV1K StarTech.com 15 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £5.32
DV1K StarTech.com 6 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £3.97
DV1K StarTech.com 3 ft Stereo Audio Cable - 3.5mm Male to 2x RCA Male In Stock £4.44
DV1K StarTech.com HDBaseT Extender Kit - 4K In Stock £261.49
DV1K StarTech.com 3-Port HDBaseT Extender Kit In Stock £406.09
