StarTech.com Dual HDMI Monitor USB-C Docking Station w/ 60W Power Deliver
Quicklinx: FLXMWS00 Mfr#: DK30CHHPDUK
Device Type: Laptop
Type: Docking Stations
Device Screen Size: [N/A]
Colour: Black, Space grey
£88.48 ex VAT
£106.17 inc VAT
This USB-C docking station is ideal for use in large organizations to meet widespread office productivity requirements and compatibility with all USB-C and Thunderbolt 3 laptops. The USB-C dock features support for Dual HDMI monitors, 60W Power Delivery 3.0, fast-charge, and both USB-C and USB-A peripheral ports.
The USB-C docking station adds dual HDMI monitors support to your workstation, with full high definitions resolutions of 1920x1080 or 1920x1200 at 60Hz. With more screen space, you can access multiple applications and reference material on one display while composing on the other.
The USB-A and USB-C charge ports can charge your smartphone, tablet or other USB peripherals whether you're working or away from your desk, and even if you disconnect your laptop.
Using a single cable, the dock powers and charges your laptop as you work with 60W PD for faster charging, using the 90W power adapter.
With a smaller size and extended length 3.3' (1 meter) host cable, this USB-C dock fits easily into a workspace environment. Even where desk space is limited, this dock can be mounted to the wall, monitor or underneath the desk with StarTech.com mounting brackets (SSPMSUDWM & SSPMSVESA). These mounting brackets are specifically designed for the docks and hubs to give you the customized setup you need.
Connect your devices with four USB 3.1 ports: 1x USB[CC2] -C and 3x USB-A. Fast-charge your USB-C or USB-A smartphone. The dock provides a GbE port (Wake-on-LAN) and a 3.5 mm 4-position headset audio jack. It also includes a security lock slot (K-slot) to protect against theft.
  • Dual Full HD 1080p HDMI Displays
  • Charge Devices via USB-C & USB-A
  • 65W Power Delivery
    Using a single cable, the dock powers and charges your laptop as you work with 65W PD for faster charging, using the 90W power adapter.
  • Convenient Setup with a Modest Desktop Footprint
    With a smaller size and extended length 3.3' (1 meter) host cable, this USB-C dock fits easily into a workspace environment. Even where desk space is limited, this dock can be mounted to the wall, monitor or underneath the desk with StarTech.com mounting brackets (SSPMSUDWM & SSPMSVESA). These mounting brackets are specifically designed for our docks and hubs to give you the customized setup you need.
  • The Connections You Need
  • Connected Device Transparency with the StarTech.com MAC Address Changer Utility
    The DK30CHHPDEU, includes a free Windows application that enables you to better manage your enterprise network security. When you connect to your network through the ethernet port of the dock, the computer's MAC address is typically not broadcast to the network, as your network only sees the MAC address of the docking station. However, the StarTech.com MAC Address Changer or Cloning software enables the USB-C dock to use MAC address spoofing of the connected Windows laptop rather than the MAC address of the dock itself. This ensures your network administrators have full visibility of each device on the network and can monitor and limit activity accordingly. To request access to our MAC Address Changer utility, please contact our Technical Support Department by phone, live chat , or e-mail .
  • The IT Pro's Choice Since 1985
    StarTech.com conducts thorough compatibility and performance testing on all our products to ensure we are meeting or exceeding industry standards and providing high-quality products to IT Professionals. Our local StarTech.com Technical Advisors have broad product expertise and work directly with our StarTech.com Engineers to provide support for our customers both pre and post-sales. DK30CHHPDEU is backed by a StarTech.com 3-year warranty and free lifetime technical support.
StarTech.com USB-C Dock, Dual Monitor 1080p HDMI Laptop Docking Station, 60W Power Delivery, 1x USB-C, 3x USB-A, Ethernet, Dual HDMI Video Display USB 3.1 Gen 1 Type-C Dock, Mac & Windows - 60W PD With Charging (DK30CHHPDUK) - docking station - USB-C 3.1 - 2 x HDMI - 1GbE
Docking station
Docking Interface
USB-C 3.1
Video Interfaces
2 x HDMI
8 cm x 15.5 cm x 2.5 cm
300 g
Black, space grey
United Kingdom
Gigabit Ethernet
Power adapter AC 120/230 V 90 Watt Power Provided
3-year warranty
Docking station
8 cm
15.5 cm
2.5 cm
300 g
Enclosure Colour
Black, space grey
United Kingdom
Video
Max Resolution Details
1920 x 1200 - 60 Hz , 1920 x 1080 - 60 Hz
2 x audio / video - 19 pin HDMI Type A , 1 x USB-C / Thunderbolt 3 with Power Delivery - 24 pin USB-C , 1 x SuperSpeed USB 3.0 with Fast Charging - 9 pin USB Type A , 2 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x audio - mini-phone 3.5 mm 4-pole
1 x USB-C cable - external - 1 m
Security lock slot (cable lock sold separately), dual monitor support, 60W power delivery
Security Slot Type
Kensington security slot
RoHS, REACH, UASP (USB Attached SCSI Protocol), USB Power Delivery 3.0
Power adapter
AC 120/230 V
Power Provided
90 Watt
Microsoft Windows 7 / 8 / 8.1 / 10, Google Chrome OS 55 or later, Apple macOS 10.12 - 10.14
Limited warranty - 3 years
Shipping Width
23.1 cm
Shipping Depth
14.2 cm
Shipping Height
8.2 cm
Shipping Weight
1.028 kg
50 °C
FLXM StarTech.com VESA Mounting Bracket In Stock £7.61
Device Type: Laptop
Colour: Black
Colour: Space grey
