StarTech.com Dual-DisplayPort KVM Cable
Quicklinx: JFZ5WS00 Mfr#: SK2DPMMKVM06-TAA-2U
£58.24 ex VAT
£69.88 inc VAT
KVM Combo Cable: Connect a dual-DisplayPort computer to a multi-monitor DisplayPort KVM switch with 2x USB host connections and audio support; Ideal for workstations and setups where clean cable management and switching between systems are essential
Optimize Cable Management: Combines DisplayPort, USB 2.0, and 3.5mm audio into a single bundled cable, reducing setup complexity and streamlining installation for a cleaner, more efficient workspace
Universally Compatible: Works with any dual-DisplayPort KVM featuring USB 2.0; OS independent, supporting all operating systems including Windows, macOS, ChromeOS, and Linux; Compatible with all hardware platforms such as Intel, AMD, and Apple Silicon
TAA-Compliant KVM Cable: Engineered for secure, reliable performance in mission-critical environments, these cables are ideal for command centers, defense operations, and healthcare facilities, ensuring seamless connectivity where it matters most
The IT Pro's Choice: Designed for reliability and compatibility with our Secure KVMs, our KVM Cables are lab-tested and field-proven for seamless integration and maximum uptime, and are backed by free, lifetime, 24/5 multilingual technical assistance
