StarTech.com Dual Desk Mount Monitor Arm - Built-in 2-port USB and 3.5 mm
Quicklinx: FVKPWS00 Mfr#: ARMSLIMDUOS
18 in stock
£139.96 ex VAT
£167.95 inc VAT
Dual Articulating Monitor Arm VESA 75x75 100x100 Height Adjustable For up to 32" Monitors. Enhance productivity and free up valuable space with the desk mount dual monitor arm. Two independent arms make it easy to adjust your dual-monitor setup.
Built-in USB Pass-Through Ports and Audio Ports
The ARMSLIMDUOS provides easy access to two USB pass-through ports and two audio ports located at the front of the base. The ports let you plug in your microphone, headset or USB devices, without having to reach for your computer.
Full-Motion Arms with Articulation and Spring-assisted Height Adjustment
The desk-mount monitor arms offer a full range of motion on several axes, letting you tilt, pan and rotate your monitors to adjust your viewing angle. The dual-arm monitor mount holds two 15" to 32" monitors and each arm supports up to 8.0 kg (17.6 lb.) of weight.
Durable Construction and Easy Setup
With its durable aluminum construction and stylish silver finish, the ARMSLIMDUOS securely holds two monitors using a standard VESA 75x75 and 100x100 mount.
The Choice of IT Pros Since 1985
StarTech.com conducts thorough compatibility and performance testing on all our products to ensure we are meeting or exceeding industry standards and providing high-quality products to IT Professionals. Our local StarTech.com Technical Advisors have broad product expertise and work directly with our StarTech.com Engineers to provide support for our customers both pre and post-sales.
ARMSLIMDUOS is backed by a StarTech.com 2-year warranty and free lifetime technical support.
  • Built-in USB pass-through ports and audio ports
  • Full-motion arms with articulation and spring-assisted height adjustment
StarTech.com Desk Mount Dual Monitor Arm with USB & 3.5mm Audio - Desk Clamp Ergonomic VESA Mount for up to 30 inch Displays - Full Motion - desk mount (adjustable arm)
Desk mount (adjustable arm)
Integrated Devices
2-ports USB hub
19 cm x 74 cm x 13 cm
Tilt
-90° to 85°
Rotation
360°
Swivel
-180° to 180°
Adjustments
Height, tilt, swivel, rotation
6.2 kg
Recommended Use
2 monitors
Recommended Display Size
15"-32"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
8 kg
Material
Aluminium
Package Content
8 x M4x12 screws, 8 x M4x30 screws, 8 x M6x12 screws, 4 x M8x12 screws, M5 hex key, M4 hex key, VESA monitor mount, 2 x rubber pads
19 cm
74 cm
13 cm
6.2 kg
Material
Aluminium
Package Content
AV Furniture
Desk mount
Design
Adjustable arm
Recommended Use
2 monitors
Integrated Devices
2-ports USB hub
Cable Management
Integrated cable management
15"-32"
Tilt
-90° to 85°
Rotation
360°
Swivel
-180° to 180°
Adjustments
Max Load Weight
8 kg
Dimensions & Weight Details
24 cm x 83 cm x 14 cm / 7.66 kg
Price Range Ex VAT: 100 - 150
