Create a Wireless-AC hot-spot from a wired network connection, or extend the range of your existing Wi-Fi network. This dual-band wireless access point, router, and repeater makes it easy to create a wireless network from your existing wired network connection or extend the distance and performance of your Wi-Fi network throughout your home or office.
Simply plug the wireless-AC range extender into a wall outlet to set up or enhance your wireless environment through one of three selectable operating modes: Access Point, Router, and Repeater.
Wireless-AC Access Point - lets you add wireless capabilities to any non-wireless router, maximizing convenience and network scalability.
Wireless Router - lets you connect multiple wireless devices together to create a private network, and enables communication between the devices and to the Internet.
Wireless-AC Repeater - extends the range of your 802.11ac wireless network to expand Wi-Fi coverage throughout your office or home. It boosts the signal to help eliminate dead spots and provides a stronger signal in areas with obstructions that would typically reduce the wireless range. The Wi-Fi range extender is also backward compatible with 802.11b/802.11g/802.11n networks, so you can use it with wireless routers that use older standards.
With its dual-band technology, this wireless AP, router and repeater provides simultaneous 2.4GHz and 5GHz connections. It delivers ultra-fast Wi-Fi speeds through concurrent 2.4GHz (300Mbps) and 5GHz (450Mbps) connections. The less congested 5GHz band is ideal for HD video streaming or online gaming.
For privacy and defense against network intrusions, the wireless-AC extender supports common Wi-Fi security protocols such as WEP, WPA and WPA2.
With a compact wall-plug design, you can install this device anywhere there's an AC outlet available. Its compact size makes it ideal for portability, and it includes detachable EU/UK/US plugs for convenient use when you travel.
- StarTech.com AC750 Dual Band Wireless-AC Access Point, Router and Repeater - Wall Plug - 2.4GHz and 5GHz Wi-Fi Extender (WFRAP433ACD) - wireless router - Wi-Fi 5 - wall-pluggable
- Wireless router
- Enclosure Type
- Wall-pluggable
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Frequency Band
- 2.4 GHz / 5 GHz
- Data Transfer Rate
- 750 Mbps
- Capacity
- Wireless clients: 32
- Auto-negotiation, auto-uplink (auto MDI/MDI-X), repeating mode, full duplex mode, Access Point operational mode, WPS, reset button, 2T2R MIMO technology, 1T1R MIMO technology
- IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Power
- AC 120/230 V
- White
- 5 cm x 6.1 cm x 7 cm
- Localisation
- North America, United Kingdom, Europe
- 2-year warranty
- Wireless router
- Enclosure Type
- Wall-pluggable
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz / 5 GHz
- 750 Mbps
- Max Range Indoors
- 300 m
- Capacity
- Encryption Algorithm
- WPA, WPA2, WEP
- Wi-Fi Rating
- AC750
- IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, FCC, RoHS
- Status Indicators
- Power, WAN, LAN, wireless, link/activity
- WAN / LAN: 1 x 10Base-T/100Base-TX - RJ-45 , LAN: 1 x 10Base-T/100Base-TX - RJ-45
Aerial
- Aerial
- Internal
- Voltage Required
- AC 120/230 V
- 4 Watt
- Enclosure Colour
- White
- Included Accessories
- 3 x wall plugs
- Localisation
- 5 cm
- 6.1 cm
- 7 cm
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 10 - 90%
StarTech.com Dual Band Wireless-AC Access Point
