KVM cable provides a reliable connection between a computer and a DisplayPort KVM switch with USB 5Gbps support. Simplify cable management by combining multiple connections into a single bundle. This minimizes the number of individual cables that need to be handled, making installation faster and more efficient. They are perfect for environments where KVMs are essential, such as data centers, server rooms, edge networking, and remote management setups, helping to reduce cable clutter and maintain an organized workspace. This KVM cable works with any operating system, including Windows, macOS, ChromeOS, and Linux. It also supports all major hardware platforms, such as Intel, AMD, and Apple Silicon. KVM combo cable is DisplayPort 1.2 compliant, supporting resolutions up to 4K at 60Hz, HDR10, and DisplayPort audio for high-quality audio/video experience. The USB 3.0 Type-A to Type-B connector provides fast data transfer speeds of up to 5Gbps.
                Manage Cables with EaseSimplify cable management by combining multiple connections into a single bundle. This minimizes the number of individual cables that need to be handled, making installation faster and more efficient. They are perfect for environments where KVMs are essential, such as data centers, server rooms, edge networking, and remote management setups, helping to reduce cable clutter and maintain an organized workspace.
                Works with Any KVM SwitchThis KVM cable works with any operating system, including Windows, macOS, ChromeOS, and Linux. It also supports all major hardware platforms, such as Intel, AMD, and Apple Silicon. KVM combo cable is DisplayPort 1.2 compliant, supporting resolutions up to 4K at 60Hz, HDR10, and DisplayPort audio for high-quality audio/video experience. The USB 3.0 Type-A to Type-B connector provides fast data transfer speeds of up to 5Gbps.
- StarTech.com 6ft (1.8m) DisplayPort and USB 5Gbps KVM Cable - keyboard / video / mouse (KVM) cable - 1.8 m
- Keyboard / video / mouse (KVM) cable
- 4K60Hz support, HDR10 support, up to 5Gbps data rate
- Length
- 1.8 m
- Connectors
- 20 pin DisplayPort - male , 9 pin USB Type A - male
- Connectors (Second End)
- 20 pin DisplayPort - male , 9 pin USB Type B - male
- USB 3.2 Gen 1 / DisplayPort 1.2
- Black
- 2-year warranty
- Jacket Material
- Thermoplastic elastomer (TPE)
- Plated Connector
- Nickel
- Length
- 1.8 m
- Black
- 320 g
- Connectors
- USB 3.2 Gen 1 / DisplayPort 1.2, RoHS
- Shipping Width
- 29 cm
- Shipping Depth
- 14.5 cm
- Shipping Height
- 3.1 cm
- 2-year warranty
|  | StarTech.com 4-Port DisplayPort KVM Switch With Built-in USB 3.0 Hub - Rack-Mountable | In Stock | £342.46 |
|  | StarTech.com 2 Pt DisplayPort KVM | In Stock | £287.20 |
|  | StarTech.com 2-Port DP KVM Switch, 8K 60Hz | In Stock | £297.72 |
|  | StarTech.com 4-Port DP KVM Switch, 8K 60Hz | In Stock | £369.44 |
|  | StarTech.com 4-Port DisplayPort KVM Switch | In Stock | £351.85 |
|  | StarTech.com Dual-DP/USB 5Gbps KVM Cable | In Stock | £23.85 |
|  | StarTech.com DisplayPort/USB 3.0 KVM Cable | In Stock | £23.52 |
|  | StarTech.com HDMI/USB 3.0 KVM Cable | In Stock | £21.69 |
|  | StarTech.com HDMI/USB 3.0 KVM Cable | In Stock | £13.41 |
