StarTech.com DP to HDMI or VGA Converter
Quicklinx: B7J0WS00 Mfr#: DP2HDVGA
33 In Stock
£16.54 ex VAT
£19.84 inc VAT
Connect your DisplayPort equipped computer system to an HDMI or VGA display. This DisplayPort to HDMI + VGA travel adapter lets you connect your DP enabled Ultrabook or laptop computer to any VGA or HDMI display.
Why keep several adapters when you only need one? With this single DisplayPort tor VGA and HDMI adapter you can rest assured that your computer can interface with any modern boardroom or classroom display. It's the ideal plug-and-play solution for BYOD (Bring Your Own Device) applications at the office.
Plus, because the converter supports video resolutions up to 1920x1200 or 1080p, you can convert your DisplayPort video source to HDMI or VGA without sacrificing video quality.
The travel A/V adapter maximizes portability with a small footprint and lightweight design. This convenient construction ensures the adapter is as portable as your laptop, fitting easily into your laptop bag or carrying case and eliminates the need to carry more than one adapter.
With this adapter you can walk into virtually any boardroom ready to present, making a great first impression and saving you the embarrassment of having to rummage through your bag looking for the right connector. Plus, the 2-in-1 converter installs easily with no software or drivers required.
StarTech.com 2 in 1 Displayport Adapter - DisplayPort to HDMI or VGA - DisplayPort Adapter - 1920x1200 - Travel Adapter (DP2HDVGA) - video converter - black
Video converter
Graphics Engine
- up to
Max Resolution
1920 x 1200
1 x DisplayPort input - 20 pin DisplayPort , 1 x HDMI output - 19 pin HDMI Type A , 1 x VGA output - 15 pin HD D-Sub (HD-15)
5.8 cm x 19 cm x 1.3 cm
Enclosure Colour
3-year warranty
Video converter
Max Resolution
1920 x 1200
1 x DisplayPort input - 20 pin DisplayPort - male , 1 x HDMI output - 19 pin HDMI Type A - female , 1 x VGA output - 15 pin HD D-Sub (HD-15) - female
FCC, RoHS
5.8 cm
19 cm
1.3 cm
37 g
Enclosure Colour
Limited warranty - 3 years
60 °C
40 - 85%
B7J0 StarTech.com Mini DisplayPort to DisplayPort / DVI / HDMI Adapter – 3-in-1 mDP Converter In Stock £20.33
B7J0 StarTech.com Mini DisplayPort to HDMI Video Adapter Converter - White In Stock £9.42
B7J0 StarTech.com 2m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £7.74
B7J0 StarTech.com 1.5m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £6.78
B7J0 StarTech.com Travel A/V Adapter: 3-in-1 mDP to VGA / DVI / HDMI Converter In Stock £9.28
B7J0 StarTech.com DisplayPort to VGA / DVI / HDMI Adapter – 3-in-1 DP Converter – Black In Stock £31.58
B7J0 StarTech.com mDP to HDMI or VGA Converter In Stock £8.35
B7J0 StarTech.com mDP to HDMI or VGA Converter In Stock £13.32
B7J0 StarTech.com DP to HDMI or VGA Converter In Stock £16.54
B7J0 StarTech.com DisplayPort to HDMI VGA Adapter - 4K 60Hz - Multiport Video In Stock £20.99
