Connect a DisplayPort-enabled desktop to 4K 60Hz High Dynamic Range (HDR)-capable HDMI monitor, using this 3.3-foot (1-meter) Active DisplayPort to HDMI Adapter Cable.
4K 60Hz HDR Capabilities
HDR improves visual quality by providing a wide assortment of colors across a dynamic range of brightnesses, resulting in a more vibrant viewing experience. The DP 1.4 to HDMI 2.0b adapter supports 18Gbps bandwidth, allowing for 4:4:4/RGB color space, 8-bit with dithering, and 7.1ch audio. It also supports HBR3 and HDCP 1.4/2.3. -
Compatibility
The Universal Adapter Cable is compatible with all hardware platforms and any operating system. Utilize integrated or dedicated GPU (Intel/AMD/Nvidia) capabilities, enabling high-performance graphics with minimal CPU usage. -
Designed and Built for IT Professionals
Integrated video adapter cable reduces points of failure, signal loss and clutter, and requires no additional power. Built with adaptive receiver equalization to optimize the input signal and amplify the output signal, to ensure display compatibility. Cage shielding prevents Electromagnetic Interference (EMI) and helps maintain signal integrity. This Active Adapter Cable works with computers from Dell, HP, Lenovo, and other desktop manufacturers. It is backward compatible with 4K 30Hz, 1080p, and other lower resolutions.
- StarTech.com 3.3ft (1m) DisplayPort to HDMI Adapter Cable, 4K 60Hz with HDR, DP to HDMI 2.0b, Active Video Converter, DisplayPort Desktop to HDMI Monitor, M/M - DisplayPort to HDMI Cord (3F-DP-HDMI-4K60-HDR) - adapter cable - DisplayPort / HDMI - 1 m
- Cable
- Adapter cable - DisplayPort / HDMI
- Length
- 1 m
- Black
- Connector
- DisplayPort - male
- Connector (Second End)
- HDMI - male
- DisplayPort 1.4
- 4K60Hz support, HDR support
- 3-year warranty
- Cable Type
- Adapter cable 4K60Hz support, HDR support
- Interface Supported
- Jacket Material
- PVC
- DisplayPort 1.4
- Length
- 1 m
- Plated Connector
- Gold
- HBR3 audio support, 7.1 audio channel support (HDMI), active cable (signal regeneration), bandwidth of 18 Gbps, bus powered, outer diameter 5mm, wide screen support, HDCP compliant, EMI protection
- Black
- Connector
- 20 pin DisplayPort - male
- 19 pin HDMI Type A - male
- RoHS
- 55 g
- Shipping Width
- 17 cm
- Shipping Depth
- 20 cm
- Shipping Height
- 1 cm
- Limited warranty - 3 years
StarTech.com 6in High Speed HDMI 2.0 Port Saver Cable with 4K 60Hz - Grip | In Stock | £10.91 |
StarTech.com DP to HDMI Adapter Cable, 4K 3m | In Stock | £21.69 |
StarTech.com DP to HDMI Adapter Cable, 4K 2m | In Stock | £20.67 |
