StarTech.com DP to HDMI Adapter Cable, 4K 1m
Quicklinx: HMP4WS00 Mfr#: 3F-DP-HDMI-4K60-HDR
£19.33 ex VAT
£23.19 inc VAT
Connect a DisplayPort-enabled desktop to 4K 60Hz High Dynamic Range (HDR)-capable HDMI monitor, using this 3.3-foot (1-meter) Active DisplayPort to HDMI Adapter Cable.
  • 4K 60Hz HDR Capabilities
    HDR improves visual quality by providing a wide assortment of colors across a dynamic range of brightnesses, resulting in a more vibrant viewing experience. The DP 1.4 to HDMI 2.0b adapter supports 18Gbps bandwidth, allowing for 4:4:4/RGB color space, 8-bit with dithering, and 7.1ch audio. It also supports HBR3 and HDCP 1.4/2.3.
  • Compatibility
    The Universal Adapter Cable is compatible with all hardware platforms and any operating system. Utilize integrated or dedicated GPU (Intel/AMD/Nvidia) capabilities, enabling high-performance graphics with minimal CPU usage.
  • Designed and Built for IT Professionals
    Integrated video adapter cable reduces points of failure, signal loss and clutter, and requires no additional power. Built with adaptive receiver equalization to optimize the input signal and amplify the output signal, to ensure display compatibility. Cage shielding prevents Electromagnetic Interference (EMI) and helps maintain signal integrity. This Active Adapter Cable works with computers from Dell, HP, Lenovo, and other desktop manufacturers. It is backward compatible with 4K 30Hz, 1080p, and other lower resolutions.
StarTech.com 3.3ft (1m) DisplayPort to HDMI Adapter Cable, 4K 60Hz with HDR, DP to HDMI 2.0b, Active Video Converter, DisplayPort Desktop to HDMI Monitor, M/M - DisplayPort to HDMI Cord (3F-DP-HDMI-4K60-HDR) - adapter cable - DisplayPort / HDMI - 1 m
Cable
Adapter cable - DisplayPort / HDMI
Length
1 m
Connector
DisplayPort - male
Connector (Second End)
HDMI - male
DisplayPort 1.4
4K60Hz support, HDR support
3-year warranty
Cable Type
Adapter cable 4K60Hz support, HDR support
Interface Supported
DisplayPort / HDMI
Jacket Material
PVC
DisplayPort 1.4
Length
1 m
Plated Connector
Gold
HBR3 audio support, 7.1 audio channel support (HDMI), active cable (signal regeneration), bandwidth of 18 Gbps, bus powered, outer diameter 5mm, wide screen support, HDCP compliant, EMI protection
Connector
20 pin DisplayPort - male
19 pin HDMI Type A - male
RoHS
55 g
Shipping Width
17 cm
Shipping Depth
20 cm
Shipping Height
1 cm
Limited warranty - 3 years
