StarTech.com DP KVM Extender Kit, 4K 60Hz
Quicklinx: HST9WS00 Mfr#: FD121-KVM-EXTENDER
12 In Stock
£613.45 ex VAT
£736.14 inc VAT
The StarTech.com DisplayPort KVM Console Extender Over Fiber Optic, 4K 60Hz, is designed to meet the needs of users requiring high-resolution video and audio signal extension over long distances. With support for 4K resolution at 60Hz, users can enjoy vibrant, detailed visuals across extended distances without compromising on quality. The extender's robust connectivity options, including DisplayPort, USB HID, and power connections, offer flexibility for various setups.
Designed for durability, the extender features a steel housing that ensures reliable performance in diverse operating conditions. It also boasts features such as 4:4:4 chroma subsampling support and EDID Pass-Through, enhancing compatibility with a wide range of devices and delivering a true-to-life visual experience. With the ability to extend signals up to 300 m over fiber optic cables, this console extender is perfect for large-scale installations in educational institutions, corporate environments, and entertainment venues.
  • High-resolution support
    Experience visual quality with support for 4K resolution at 60Hz, ensuring crisp, detailed images and vibrant colors for an immersive viewing experience.
  • Robust connectivity
    Featuring a wide range of inputs including DisplayPort, USB HID, and power connections, this extender offers versatile connectivity options to meet various user needs.
  • Extended reach
    With the ability to extend video, audio, and USB signals up to 300 m over fiber optic cables, this console extender ensures high-quality, long-distance transmission without signal degradation.
  • Durable design
    Constructed with a steel housing, the extender is designed for durability and reliability, ensuring long-term performance in diverse operating environments.
  • Enhanced compatibility
    Supports 4:4:4 chroma subsampling and EDID Pass-Through, enhancing compatibility with a wide range of devices and delivering a true-to-life visual experience.
StarTech.com DisplayPort KVM Console Extender Over Fiber Optic, 4K 60Hz - video/audio/USB extender - DisplayPort - TAA Compliant
Video/audio/USB extender
External
DisplayPort
Max Transfer Distance
300 m
AC 100-240 V
7.8 cm x 11.4 cm x 2.8 cm
500 g
TAA Compliant
External
Wired
DisplayPort
Max Resolution
3840 x 2160
300 m
Status Indicators
Status, USB HID 2
4K resolution support, EDID Pass-Through, 4:4:4 chroma subsampling support, steel housing, wide screen supported, EMI protection
1 x - SFP+ female , 3 x USB HID (input) female , 1 x DisplayPort (input) , 1 x power - micro-USB Type B , 1 x DisplayPort , 1 x - micro-USB Type B , 1 x power - micro-USB Type B
2 power adapters
1 x USB power cable
MTBF
156,000 hours
FCC, RoHS, MSA
TAA Compliant
External power adapter
AC 100-240 V
10 Watt
7.8 cm
11.4 cm
2.8 cm
500 g
Shipping Width
30.6 cm
Shipping Depth
17.5 cm
Shipping Height
7 cm
Shipping Weight
1 kg
50 °C
0 - 80% RH (non-condensing)
HST9 StarTech.com OM4 Multimode Fiber Cable 20m In Stock £64.73
HST9 StarTech.com OM4 Multimode Fiber Cable 25m In Stock £67.29
Price Range Ex VAT: £500 - £750
